Lighting Display
+5
9 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: Lighting Display
Well managed to get a bit more on it done today so here's some updated pics, nothing is fixed in place yet and it still needs the gear box and a good couple of coats of varnish but were getting there
Thats looking fantastic abes , will looks the dogs nuts once all finished
And I'll have a couple of shots from the end optic mate............
DanBoy- Life Member
LOL thats why i dont get much work done
DanBoy wrote:And I'll have a couple of shots from the end optic mate............
Looking good
Cracking job Abes, keep us updated on your progress as it's going to look great when finished.
Cheers mate will do, next job is to fit the gear box underneath, does anyone know if it matters if these little Jap generators run clockwise or anticlockwise, its running clockwise at the moment but once the gear box is fitted it will reverse the rotation now i know i can just put a twist in the v belt but would prefer not too, any help much appriciated
Few more pics of some progress today, managed to clean and polish the brass and paint the gear box and get that in position also managed to make a start on the varnishing
Thats looking fab abes what type of varnish do you use i love the colour of it .
Cheers Matt, not sure what make of varnish it is though it is a marine one will check later and let you know, still need to source 2 x 3" v belt pulleys then its just a case of finish the varnishing and put it all together and the job will be a goodun
matt86_wd2 wrote:Thats looking fab abes what type of varnish do you use i love the colour of it .
Abes wrote:Cheers Matt, not sure what make of varnish it is though it is a marine one will check later and let you know, still need to source 2 x 3" v belt pulleys then its just a case of finish the varnishing and put it all together and the job will be a goodunmatt86_wd2 wrote:Thats looking fab abes what type of varnish do you use i love the colour of it .
abes try bearing boys .... google it mate .
Oh im thinking to come down south the weekend of 24th .... anytime after 13.00 suit you ?
Abes wrote:Cheers mate will do, next job is to fit the gear box underneath, does anyone know if it matters if these little Jap generators run clockwise or anticlockwise, its running clockwise at the moment but once the gear box is fitted it will reverse the rotation now i know i can just put a twist in the v belt but would prefer not too, any help much appriciated
Not certain Abes, I know that vehicle dynamos can run both ways when new but when worn the brushes get 'shaped' in the direction of rotation. You might have to turn them around so that they are running the same way again or the sharp unworn edges can snag the armature segment's?
Yer tried the bearing boys had none in the size i need ie 3" with a bore of 3/4", ref the weekend would that be the Saturday or the Sunday your thinking of
matt86_wd2 wrote:Abes wrote:Cheers Matt, not sure what make of varnish it is though it is a marine one will check later and let you know, still need to source 2 x 3" v belt pulleys then its just a case of finish the varnishing and put it all together and the job will be a goodunmatt86_wd2 wrote:Thats looking fab abes what type of varnish do you use i love the colour of it .
Cheers for the info mate ive put a new set of brushes in and so far they've had very little use so would i still need to turn them round
Foden wrote:Abes wrote:Cheers mate will do, next job is to fit the gear box underneath, does anyone know if it matters if these little Jap generators run clockwise or anticlockwise, its running clockwise at the moment but once the gear box is fitted it will reverse the rotation now i know i can just put a twist in the v belt but would prefer not too, any help much appriciated
If you have renewed them then you should be ok. You will just have to connect everything up and try it rotation wise, wouldn't think that it should cause any problem.
nearest i can find on ebay
http://www.ebay.co.uk/itm/RDGTOOLS-3-3-8-V-PULLEY-3-4-bore-V-BELTS-/290460130813?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&hash=item43a0c5ddfd
hob- Life Member
Cheers Pete thats great, hopefully thats one less thing to worry about then
Foden wrote:If you have renewed them then you should be ok. You will just have to connect everything up and try it rotation wise, wouldn't think that it should cause any problem.
Cheers for tracking them down for me much appriciated was hoping to pay a little less than that but if i cant source cheaper then these would fit the bill great
hob wrote:nearest i can find on ebay
Abes wrote:Yer tried the bearing boys had none in the size i need ie 3" with a bore of 3/4", ref the weekend would that be the Saturday or the Sunday your thinking ofmatt86_wd2 wrote:Abes wrote:Cheers Matt, not sure what make of varnish it is though it is a marine one will check later and let you know, still need to source 2 x 3" v belt pulleys then its just a case of finish the varnishing and put it all together and the job will be a goodunmatt86_wd2 wrote:Thats looking fab abes what type of varnish do you use i love the colour of it .
sat abes ... il give you a ring regarding pully mate i mite be able to get you from a place we deal with at work ..
I had a supplier of pullies etc but can't find it now (always the case) I had a look in the suppliers thread on the forum but it's not there if I find it again soon I'll let you know Abes.
Cheers mate many thanks
stationary stu wrote:I had a supplier of pullies etc but can't find it now (always the case) I had a look in the suppliers thread on the forum but it's not there if I find it again soon I'll let you know Abes.
abes.can you do a step by step guid.on how you do the stove blacking bit on your engines & does water oil & petrol efect it in any way.
dave.
dave.
Diddy- Life Member
Not a problem mate but ill do it as a seperate thread, wont get a chance tonight but will do it at the weekend
Diddy wrote:abes.can you do a step by step guid.on how you do the stove blacking bit on your engines & does water oil & petrol efect it in any way.
dave.
Quick update managed to get a bit more done over the last couple of nights, have managed to source a couple of bakerlite switches so the box has now been wired up and checked using a 12volt battery i have, not too bright due to the bulbs being 20volt but only used just to prove everything worked ok, was suprised everything worked as crap with electrics lol, have also black top coated the uprights have given the feet and box a second coat of varnish and also done the underneath of the main bed just the sides and top left to do, pics below
now that is looking good.keep up the good work & more pics as well.
Diddy- Life Member
» Delcolite lighting set.
» Stuart Lighting Set
» Lighting board designs
» lister cs 6/1 startomatic lighting plant 2.5 kw
» This years display
Page 2 of 4
