Lighting Display
Page 3 of 4 Previous  1, 2, 3, 4  Next
Re: Lighting Display
Post by Abes on Fri Mar 09 2012, 20:09
Well at last the building work is finished just a small V belt to source and the jobs a good un pics below
Post by matt86 on Fri Mar 09 2012, 21:57
Thats a nice set up Abes ... how did you cut the slot out .... drilled holes and used a jigsaw .... ?
Post by Diddy on Fri Mar 09 2012, 23:33
could be like the rest of us matt.used a router.
Post by matt86 on Sat Mar 10 2012, 08:10
Dave a router does not go that deep does it .... as by looks of it that wood is quite thick ... well you could not go that deep in 1 pass could you .... as you can only go down 1/22 at a time without putting much strain on the router ...
Post by mike d on Sat Mar 10 2012, 10:00
hi abes...
the lighting set is progressing very well,im thinking i need to come to yours to see how you have wired it up
as once my shed is all up and running i will be able to try and sort mine out,its exactly the same as yours
i was going to use it to charge my scooter batteries up when at a show...
will contact you to see the best time to come round
keep up the cracking work..regards...mike....
Post by stationary stu on Sat Mar 10 2012, 11:26
Great bit of work Abes, it will make a great display, something different you may even win a prize for it.
Top work,
Post by Abes on Sat Mar 10 2012, 13:23
Cheers gents for all the comments much appriciated as said its now finished was going to put a tin roof on it but have decided against it, just wanted something easy to move around and a bit diffrent hopefully thats what ive achived.
Mike - Not a problem mate can come round any time just give us a shout do have a load of pics of the inside of the control box if you need any.
Matt - was going to use the router like the lads suggested but in the end found it easier boring a hole at each end and using the jig saw
Post by mike d on Sat Mar 10 2012, 14:24
hi abes....
i would call you but don't have a land line number for you...will have to email you or PM you on here..
mike..
Post by mike d on Sat Mar 10 2012, 16:19
abes..ive now been given you land line number by the feller from swindon..hope you don't mind...
Post by Abes on Sat Mar 10 2012, 17:45
No not at all mate, of cause you could have just asked Ian he would have given it too you lol
Post by Diddy on Sat Mar 10 2012, 19:09
abes.are you going to put a video of it up & running m8.
Post by Abes on Sat Mar 10 2012, 19:29
Hi mate yer will do just have to source a v belt to link the gear box to the generator which should be next week
Diddy wrote:abes.are you going to put a video of it up & running m8.
Post by Abes on Sun Mar 11 2012, 18:29
Hi all iam after a bit of help, had my engines running today (will put a post up later) well while i had them running thought i would try out the lighting set to see what it looked like so i belted it direct ie bypassed the gear box as still need to source a drive belt, its at this point i found i might have a small problem with the volt meter, the volt meter needle just seems to vibrate between 0 and 3 volts and does not do anything eles even when i alter the voltage setting via the generator, but the strage thing is when i re-connect it to a 12 volt battery it does exactly what it should do ie show 12 volts, the bulb and switch works fine on either generator or battery, have i done something wrong or is there something i should have done, any and all help much appriciated.
Post by Diddy on Sun Mar 11 2012, 22:50
wires are the rite way round.just a thought.
Post by Abes on Mon Mar 12 2012, 18:51
Fixed it yippeeee, baffels the hell out of me how though took the wires off made some new ones wired it back up the same connected the generator to a motor ive got and Bobs your cousins sister up she went, volt meter now shows the right output and bulb and switch do what they should do, figure that lol
Post by stationary stu on Tue Mar 13 2012, 12:22
Could be a dry joint if there soilderd on, they tend to cause strange problems.
Post by mike d on Tue Mar 13 2012, 18:43
i smoked a dirty joint years ago,didn't enjoy it at all...lol.lol.lol..
mike....
Post by stationary stu on Wed Mar 14 2012, 10:54
I found this on ebay, now this would make a good lighting display lol! lol!
http://www.ebay.co.uk/itm/251016674581?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_1413
The same seller also has some chimes for sale if you want to pi** off the local kids lol! lol! lol! lol!
Post by matt86 on Wed Mar 14 2012, 11:44
now stu common in what context has that got to do with a lighting display ....? Laughing :offtopic[1]: :offtopic[1]: :offtopic[1]: lol!
Post by stationary stu on Thu Mar 15 2012, 11:29
Stick a bulb in the cone, get all the kids screaming at the rally for an ice cream Twisted Evil Twisted Evil Twisted Evil
Post by DanBoy on Thu Mar 15 2012, 13:22
matt86_wd2 wrote:now stu common in what context has that got to do with a lighting display ....? Laughing :offtopic[1]: :offtopic[1]: :offtopic[1]: lol!
Sure got me licked.... Rolling Eyes
DanBoy
Post by stationary stu on Fri Mar 16 2012, 11:02
Everything has to be cone sidered for a display Very Happy lol! lol!
Stu,
Post by Abes on Fri Mar 16 2012, 17:56
This post is just getting silly infact its got me Licked lol!
Post by YorkshireChugger on Fri Mar 16 2012, 20:29
It almost reminds me of those adverts for Bulletproof Vests. "Buy me and Stop One".
Or something like that.....
taxi!
YorkshireChugger
http://wr5harrogatehomeguard.webs.com/
Post by stationary stu on Sat Mar 17 2012, 11:35
YorkshireChugger wrote:It almost reminds me of those adverts for Bulletproof Vests. "Buy me and Stop One".
taxi!
There was a condom advert the same lol! lol! lol!
