JAP 2A with Rapier Ransomes pump.
Post by piston ring on Mon Mar 12 2012, 22:42
Hi,
This is my latest aquisition.
piston ring
Re: JAP 2A with Rapier Ransomes pump.
Post by piston ring on Mon Mar 12 2012, 22:43
More work.
piston ring
Post by hob on Tue Mar 13 2012, 00:02
Hi there interesting video's
just a small point which may interest you, living near Ipswich i can tell you the name is the wrong way round the company was called
Ransomes and Rapier
see Grace's guide for more info
http://www.gracesguide.co.uk/Ransomes_and_Rapier
regards Neville
Post by DanBoy on Tue Mar 13 2012, 11:23
Nice little unit that. I do like the Japs and Villiers engines.
DanBoy
Post by stationary stu on Tue Mar 13 2012, 11:44
Thanks for posting the videos very interesting, hope you sort out the problems with it as it will make a cracking display once it's finished. I have a Jap 2a partly stripped at present waiting for me to put some new rings in as when I bought it, it was very low on compression so hopefully new rings and the valves ground in should sort it, just need the time to do it.
Please keep us informed of any up dates of what you find wrong(if anything)
Post by piston ring on Tue Mar 13 2012, 23:03
Thanks for your replies. I was advised today that the way I removed the flywheel could have strained the threads on the nut and shaft. After removing the rope pulley I placed the nut back on the shaft a couple of turns and whilst pulling on the flywheel hit the nut with a hide mallet. Any views on this would be welcome.
Cheers,
Des.
piston ring
Post by mike d on Wed Mar 14 2012, 00:08
hi Des...
looks like you have been busy..
thanks for sharing the videos with us all
should help some members on here...
keep up the good work
