Fuel pipe fittings
Fuel pipe fittings
Post by Abes on Tue Apr 17 2012, 20:21
Right might be a stupid question but here goes, need to make a new fuel pipe for the PAB both the tank and the carb have male screw fittings but what do i measure to find out what nut and nipple i need also what size pipe should be used
Re: Fuel pipe fittings
Post by matt86 on Tue Apr 17 2012, 21:39
Abes wrote:Right might be a stupid question but here goes, need to make a new fuel pipe for the PAB both the tank and the carb have male screw fittings but what do i measure to find out what nut and nipple i need also what size pipe should be used
do you know the diameter of the center hole in the fitting ? is there any old pipework left from original pipework ?
What size is the male threads Im guessing would be 1/4 as that is what the fuel pickup is on the A cant see why it would need to be bigger ,
Post by hob on Tue Apr 17 2012, 22:30
Abes, fuel fittings are usually BSP thread
a chart showing sizes can be downloaded here
by clicking on "Download our guide to BSP thread sizes"
http://www.pipefittingsdirect.co.uk/
you can measure your male fittings and get a BSP size from the chart.
a range of pipe and fittings are available here
http://www.vintagecarparts.co.uk/categories/vintage-car-parts-taps-pipe-and-fittings
