another one.
another one. Empty another one.
Post by earlsinclare Sat Sep 15 2012, 15:58
a stuart turner r2. don't know much about this engine but it is complete has compression and does spark.
another one. 00511
if anyone can pass on any information on the r2 i would be grateful.
thanks richard.
earlsinclare
earlsinclare
another one. Empty Re: another one.
Post by steve w Sat Sep 15 2012, 21:24
nice looking engine
Post by Guest Mon Sep 17 2012, 12:31
Very nice Richard so you found what you wanted you must be happy with it. I've heard that David Edgington can date these engines but not sure what other info he can supply.
another one. Empty update on my r2.
Post by earlsinclare Sat Oct 06 2012, 18:37
i put my r2 on a frame and started to couple it to my vacuum pump ( still looking for a stuart pump ). a bit of old angle and the welder and i came up with this.
another one. 00810
got to come up with a way of connecting them next.
any ideas?.
richard.
earlsinclare
earlsinclare
Post by Guest Sun Oct 07 2012, 10:22
Nice job Richard, it's strange I was thinking the same to use angle iron to build a frame for my P5 so I can then set the cooling tank and fuel tank on angle also.
As for joining the two together all I can think of is some kind of sleeve then clamp it on. Don't know if you could get some solid round bar bored out to the size you need then put a split in each end and clamp with maybe just 2 hose clips each end so it's not to out of balance.
Post by matt86 Sun Oct 07 2012, 10:51
stationary stu wrote:Nice job Richard, it's strange I was thinking the same to use angle iron to build a frame for my P5 so I can then set the cooling tank and fuel tank on angle also.
sleeve made with keyways cut to suit engine and pump then a peice of key steel in each keyway with a grub scre or pinch bolt ... Thats what i would be tempted to do .
Post by Foden Sun Oct 07 2012, 13:23
My old vacuum pump lives Richard! Pleased that you found a use for it. Very Happy A pity that the shaft's are different diameters else you could use a rubber hose and jubillee clips, same as on JAP charging sets and Gardner alternator's. At least then if the pump should sieze up the rubber drive would break.
another one. Empty sat in the shed
Post by earlsinclare Sun Oct 07 2012, 13:43
Foden wrote:My old vacuum pump lives Richard! Pleased that you found a use for it. Very Happy A pity that the shaft's are different diameters else you could use a rubber hose and jubillee clips, same as on JAP charging sets and Gardner alternator's. At least then if the pump should sieze up the rubber drive would break.
its been sat in the shed since you sent it to me peter, the pump gives the stuart enough load to make it run nice. the connector shouldn't be a problem now, lots of good ideas from the forum members.
richard.
earlsinclare
earlsinclare
