flywheels need sorting
Post by RAB on Sun Sep 20 2009, 21:28
as you can see i just bought the duetz, the paintwork is good, but flywheels dont look the best what can i do to bring them up
Re: flywheels need sorting
Post by iansw on Sun Sep 20 2009, 22:14
Sorry Ryan, :wtf: but i thought it was your wifes engine :hidesbehindsof , leave her alone to do it herself and you get them dishes washed :hysterical: :hysterical: :hysterical:
iansw
yeah it hers
Post by RAB on Sun Sep 20 2009, 22:29
but this engine is a beast and she needs the help :hysterical:
Post by iansw on Sun Sep 20 2009, 22:55
I am sure she can handle it, she has you sorted scratch :hysterical: :hysterical: :hysterical:
iansw
Post by BRASSO on Mon Sep 21 2009, 07:24
Ryan,
Go down to the place at Portreath and buy an abrasive flap wheel. (think I used a 240 grit one).
Fix it in your drill, and that fly wheel will come up like a new penny.
I think they are approx £8, and they last for ages. (saves on the old elbows)
Thats what I used on my Flywheels, works a treat without having them skimmed.
Post by JONESEY on Mon Sep 21 2009, 08:03
Ryan ,Good old wire brush while running then some emery cloth.
then still while running brasso on a rag, then polish off.
stop engine polish with grate black leave to dry .
Polish off you have a great finish no oil or grease everywere and the dirt dont stick to it Smile
this last for about 3 months then you just black it again.
All my engines I do like this Smile
someone said wet and dry
Post by RAB on Mon Sep 21 2009, 10:13
someone said wet and dry while running is this correct????????????
Post by JONESEY on Mon Sep 21 2009, 17:53
If you want to cover you and the engine in rusty water thats fine :hysterical: :hysterical: :hysterical:
Chris :babe2: Now I could wet and dry this
ill go with the wire brush
Post by RAB on Mon Sep 21 2009, 18:32
ill go with the wire brush idea then cheers cheers cheers
Post by mike d on Mon Sep 21 2009, 22:36
sounds like the safer option
jonesy's idea could get you into trouble
nice thought thou chris
mike
Post by Guest on Tue Sep 22 2009, 13:04
ryan wrote:ill go with the wire brush idea then cheers cheers cheers
be very very careful with wire brushing flywheels, because you are subjecting the wire brush to high speed motion, they risk flying apart dead easy, they arent like cup brushes, they are not designed for that kind of work and the wires will fly everywhere, including your skin Crying or Very sad
best thing to do is progrssively finer grades on wet and dry, though just use it dry with some (moist lol) soap on, much safer so long as you keep your hands away from and trapping points
before and after
Post by RAB on Tue Sep 22 2009, 16:08
before after
the smears on the flywheels
Post by RAB on Tue Sep 22 2009, 16:10
the smears on the flywheels are just a little oil i put on cheers
Post by iansw on Tue Sep 22 2009, 21:47
Ryan, i see you have found the hopper drain or have you had a quick pee in the corner and it's run under the engine :hysterical: :hysterical:
iansw
yeah i drained the old water
Post by RAB on Wed Sep 23 2009, 03:55
and forgot to put the plug back in cheers cheers
