Duetz oil?????????????????/
Post by RAB on Mon Sep 21 2009, 10:22
Never had a diesel before, so what oil is best to use in them, i havent a clue, checked it its slightly under so need to sort it cheers
Re: Duetz oil?????????????????/
Post by JONESEY on Mon Sep 21 2009, 17:51
Deisel oil :hysterical: Drain it out and borrow :hysterical: some from work the same as that old Scania uses
so just normal heavy oil then
Post by RAB on Mon Sep 21 2009, 18:31
ill sort that tommorrow cheers cheers
Post by Roadster on Mon Sep 21 2009, 21:56
It is better not to use a modern multigrade in an older design of engine. The additives in modern oils do not suit the older bearing alloys. For an engine which is not doing any work it probably does not matter but if you are thinking of working it then use a straight grade high detergent oil. Shell Rotella 30 was probably one of the best. I use Exol classic HD30 for the Gardners etc which I look after. I can let you have some as I buy it by the 205l drum.
Rod
Roadster
Post by mike d on Mon Sep 21 2009, 22:04
i bet the fuel consumption goes all to c**k now you have a diesel lol! lol! lol! lol! lol!
told you to come and get that PETTER M
its cheap enough and its paraffin
dont leave it to long
mike.
one day mike
Post by RAB on Tue Sep 22 2009, 04:27
one day, lol , thanks for the advice, roadster
Post by iansw on Tue Sep 22 2009, 08:48
JONESEY wrote:Deisel oil :hysterical: Drain it out and borrow :hysterical: some from work the same as that old Scania uses
but without the sawdust :hysterical: :hysterical: :hysterical:
iansw
