dating of two B&S engines
Post by bbs on Sun Jun 17 2012, 16:39
I have here two B&S engines and I would like to know how old this engines are. The first is a model 60331, type 942047, serial number 163396 and I find another number 5905060.
The second is a model 80202, serial number 0016-01 730, serial number 1197766.
Who can tell me more about this engines?
bbs
Re: dating of two B&S engines
Post by stationary stu on Mon Jun 18 2012, 10:03
Model Information & System Of Names
Every Briggs & Stratton engine has a basic model letter or number such as A, WM, ZZ, 5, 23, etc. This will be found on the metal nameplate if it is present on the engine. The early F Series has the Model & Serial number stamped into the crankcase.
Early engines (up to somewhere in the 1940's) have a brass plate on the shroud and later engines have a zinc or aluminum plate on the cylinder shield.
Engines having special features are identified by additional letters or numerals assigned to the basic Model Letter or Number such as AL, 8R6, NS, etc. For Example the 8R6 is a model 8 engine with a 6:1 reduction gear and the NS is a model N with a suction carburetor. An explanation of these suffix letters is given below.
Could you tell me the model number please.
Engines are just like Pringles .... one is never enough.  [You must be registered and logged in to see this image.]   [You must be registered and logged in to see this image.]    [You must be registered and logged in to see this image.]     [You must be registered and logged in to see this image.]                [You must be registered and logged in to see this image.]    [You must be registered and logged in to see this image.]    [You must be registered and logged in to see this image.]    [You must be registered and logged in to see this image.]  I used to love tractors all I would ever think/talk about. Then one day out of the blue I went on to statinary engines, So you could say I'm an extractor fan. [You must be registered and logged in to see this image.]
Post by bbs on Mon Jun 18 2012, 15:13
The first is a model 60331 and the second a model 80202. I have also a model 6 and I know that this engine is from 1954, and I like it to know how old my engines are and another numbers stay in my previous post.
bbs
Post by stationary stu on Tue Jun 19 2012, 12:03
You should be able to find out all the information you need here.
Post by DanBoy on Wed Jun 20 2012, 10:35
That's the one I use Stu. bbs, you really need to find the engine Type, e.g. ZZ, M series etc....
I intend to live forever - so far, so good! [You must be registered and logged in to see this image.]
DanBoy
Post by stationary stu on Wed Jun 20 2012, 10:48
That's what I was trying to get at Dan, but I'm sure he can sort it out himself now.
