Villiers mk 20 carb
Villiers mk 20 carb
Post by ericthommo on Mon Jun 18 2012, 13:36
G'day just looking for a bit of advice on a viliers mk 20 carby, dont know what the brass ring is for on the inside of unit? any info much appreciated.
ericthommo
I really need to post more
Re: Villiers mk 20 carb
Post by kevjhnsn on Tue Jun 19 2012, 03:05
ericthommo wrote:G'day just looking for a bit of advice on a viliers mk 20 carby, dont know what the brass ring is for on the inside of unit? any info much appreciated.
were abouts in the carb are you talking mate
if its about were the intake is, and it has a grove down one side and i steped down in outer sizes ,and the long brass center piece goes trough the center of it into the float bowl ,
**then it the "throat choke" for the compensating tube jet system ,as this part is changed for the different engines that they fitted this style carb too mate
as they were on villiers's from about 98cc mk10 to 256.5cc on the mk25
and also machined different again for the petrol /paraffin vapourizer engine----------------------as here on my mk25 avatar pic-------------------->
hope this helps you
