bernard moteur repaired
Post by kevjhnsn on Sun Jul 01 2012, 16:35
at 1000 engine my mate bought a bernard air cooled frence engine for 20 pounds
no compression ,no spark and asked me to take it home and see if hes bought a "pug" think he means a dog lol and if so see it on for him
strippped it down valves stuck solid freed them off ,and lapped back in sanded the bore for a deglaze run redex in plughole last week
cleaned it all up and grit from stuck the engine back together with results of little compression ,but a lot more than earlyer today
stripped the wierdest electrics ive worked on and cleaned every thing back up set points ect ect turned it half a turn buy hand and a brilliant blue spark Very Happy Very Happy freed fuel tap and cleaned tank through it all back together and heres the results
hes due to call me tonight so he wiill be happy for a while until i get to the when warmed up and running on tick over it oils the plug up and smokes when starting again
Re: bernard moteur repaired
Post by kevjhnsn on Sun Jul 01 2012, 17:00
well as ive now found out its a w12 bernard
and it looks a bettter runner than this one
Post by JONESEY on Sun Jul 01 2012, 23:42
Sounds great Kev nice compacted engine
Post by stationary stu on Mon Jul 02 2012, 09:52
Sounds Fine Kev, nice bit of work, did you check to see if any rings were stuck or just put red x down?
Post by kevjhnsn on Mon Jul 02 2012, 14:41
stationary stu wrote:Sounds Fine Kev, nice bit of work, did you check to see if any rings were stuck or just put red x down?
i just redexed it as at the time didnt know if there was any other knackered bits on it so will be dropping the sump off it know
as he wants it doing as best i can for him
he says will pay for rings if needed "this time for a change " Smile lol!
"for a engine that you dont see parts for very often in this country confused confused lol"
Post by stationary stu on Tue Jul 03 2012, 10:41
You'll have to learn French and get on French ebay for parts lol! lol! lol!
