Whats happening here?????????????????
i seen this video of another duetz, but what is the bloke sticking into the head, i have that unscrewy thing aswell, but havent used it yet, should i be
Re: Whats happening here?????????????????
That is a cold starting aid
I cant remember the proper name for them ,
Effectively what happens is they are put in the inlet manifold or like on that engine inside the top of the cylinder and they ignite like a match under the compression of the engine .
This helps the engine to start under very cold conditions
Steve
Steve
Avandriver- Expert
what is it exactly
Avandriver wrote:That is a cold starting aid
Steve
is it like a piece of paper dipped in diesel and dryed out or summit, like i said, i have got that thingy that screws in and out, but do i need to use it, it starts well most of the time, if someone knows exactly what they are i may try it, see if it makes a difference
If you look at the comments posted on the youtube page there is a explanation of what it is there .
If your engine is an easy starter then you dont need to use them
Steve
Steve
Avandriver- Expert
It works like a glow plug, the field marshalls have them, its just a cigeratte paper really!
cheers
cheers
Lister John- A credit to the forum
Its a reefer it is what make a diesel smoke :hysterical: :hysterical: :hysterical:
If your, sorry Laurens engine starts easely without it then don't bother and never use EASY START if it gets harder to start, you would be better off useing a blow tourch down the intake :smokin: :smokin:
:cheers2:
:cheers2:
iansw- A credit to the forum
you dont want to go down the easy start road
once an engine gets a sniff of that stuff
it wont start without it
i used to have an old London taxi years ago that loved the stuff
sold it to a breakers yard in the end
was costing me a small fortune to start the thing
glad to see the back of it
Lister John wrote:It works like a glow plug, the field marshalls have them, its just a cigeratte paper really!
cheers
yeah johns on the right lines
it will be one of to things
Touch paper, which you light then place into the cold start holder,
or A starting Cartridge, which is granules of Carbon, and explosive material to detonate in the engine.
yeasterday i
could not get the duetz to start, so i rolled up a rizala and dipped it in diesel, popped that in that screwy thing, 1 crank she went off like a rocket, so this screy thing must be quite important, good news shes still holding compression
I first came across them years ago to start a Hatz engines, they looked like a small tampon with a pink/red tip. I don't know what it was coated with but it worked every time. I had a tin of them but threw them out a few years back. If I'd only known they might be of use to someone one day as they were still dry and perfect with being kept in the time.
thats correct stu
spoke to guy today who use to own the duetz, he doesnt know what exactly they are either, but he use to do same as me with the fag paper
» First lister D, and first time everything else in old engines.
» Just thought I would show you whats on its way over to me
» wittes engine whats it worth?
