Preparring engines for winter
I was just wondering what you all do to prepare your engines for the winter
Re: Preparring engines for winter
Empty all water out.
Clean any rusty bits & oil then & Oil up all flywheels etc. and cover with clingfilm.
Put in back of garage and cover over with dust sheet and plastic cover.
BRASSO- Life Member
Dont cover with plastic sheet, just the dust cover they will swet
Hi all,
In your last tank of fuel for the year put a drop of 2 stroke oil in with the fuel, it will put a linning on the inside of the tank and stop it rusting.
so is it ok to leave the fuel tank empty????????????????????
Yes but there are plenty of playing days in the winter
leave the tank empty but open the fuel tap and remove the fuel pipe so any condensation can drain out..if you got water cooled engines either drain the water or add a bit of anti freeze to the water..leave the engine on compresion stroke to keep the valves closed.and if you can turn the engine over every now and then and add a bit of oil to the bores to stop anything seizing.
jay- A credit to the forum
does this have to be done
even if there going to be wrapped up warm in a garage,if so what grade anti freeze is best, thanks
jay wrote:leave the tank empty but open the fuel tap and remove the fuel pipe so any condensation can drain out..if you got water cooled engines either drain the water or add a bit of anti freeze to the water..leave the engine on compression stroke to keep the valves closed.and if you can turn the engine over every now and then and add a bit of oil to the bores to stop anything seizing.
good call jay.........your going to enjoy it on this forum........
regards......mike d
ryan wrote:i were going to leave mine empty, is it a good idea ???????????
even if you leave your tank with diesel in Ryan, condensation will still get to the bottom of the tank and cause rot to occur.
i use antifreeze in my engines, much to the chagrin of some other guys, however we get some savige weather up here, and none of the engines have come anywhere near freezing yet.
now mags can be an iffy subject, in a damp shed its beneficial, if you can, to remove the Mags, but sometimes its just not possible, one thing you can do, is to put a sachet of silica gel into the mag, this will absorb any moisture that might get into there, i havent tried this myself, but it may be worth a bash.
one cool dude
Get out there once a month and give them a crank up I pulled my out in the snow last year
i bet that in that snow was cold......must have shriveled up
mike
mike
I keep the old oil from oil changes and using a paint brush give the engine a coat of oil, more so the flywheel or places that rust would normally form. (Could be messy so don't do it on the patio .) Then next year just wash it off with gunk or something similar.
Stu
Stu
i always have cranked them
up every couple of weeks, give them a good run, dont like them being stood still for to long
Play time in the snow as you can see I run mine when the suns out it was lovely and cold
I had cleared the drive got a snow plough for the ride on mower
this was Feb of this year,with my helper watching [no longer with me ]
shoot........you must be high up in that castle......we've got rain down here.....
mike.
mike.
jonesey no the way you must have felt
we had two springers, spike and gilbert, spike is 5 we have had him from 6 weeks old, he comes to all the rallys, sadly gilbert died in may only 2 years old, he eat building sand that contained lime, we didnt even know he done it, that kind of dog put there nose everywere, it destroyed me, still not over him now, the older one has gone a little quiter now, but we try and keep him as active as possible, i think it hurt so much as the pair use to go everywere with me, and to lose one it was horriable, this is a picture of him
I now were your coming from Ryan Chocky was 14 I had her from a puppy I had to take on her last vist to the vets,she just got old I was not going to let her suffer
» my new project for the winter
» This is my new project for the winter
» ENGINE PRICES
» winter project...but what is it?
» new projects / winter projects
» ENGINE PRICES
