Petter A1 restoration project
Page 2 of 4 Previous  1, 2, 3, 4  Next
Re: Petter A1 restoration project
Post by sjs205 on Thu Jul 19 2012, 20:40
hob wrote:
sjs205 wrote:Hello all,
This one is of the magneto that I have, it is a Wlco series A. I've noticed that the mounting bracket is slightly offset... Can this bracket be adjusted or will I need a different Mag?
Steven
comparing pictures of my mag with yours i begin to see what you mean...........your mounting flange is offset the opposite way to mine
i don't see any blue paint on the engine in your original photo's of the engine...........maybe its not from that engine?
I have just been given 3 Petter A1 engines by a friend, they are all in poor states but I have taken the best from the bunch and plan to start restoration over the coming weeks - need something to do while the weather is so awful!
Steven
what are the other 2 engines like? and do they have mags with them.
One of the other ones has a mag, but my friends father has been "restoring" this for the last two years... my friend said that I could take them all since his father hasn't looked at it for the last 18 months and seems to have got bored with it, but I want to wait to confirm it with him before I start ripping parts off of it. This one also has a round fuel tank and pepper pot exhaust... But I still maintain that mine is the better engine Smile
I know it is as good as mine, but I want to see him before I just take that one...
I have this mag here on my desk now, I can see that the mounting bracket will come off but I can't swivel it, so it is definatly stuck at this angle.
So my question for now is, does anyone have a bracket the right way around for sale? Or even a broken Mag?
sjs205
Post by nutgone on Thu Jul 19 2012, 20:57
pauldg wrote:I started using plus gas in the late 80's, early 90's - that wasn't the spray one though, it was in a tin. Maybe it's more concentrated like that?
I was one of the ones talking about stripper - if you're happy with the 'new formula', eco-mental-friendly, non-toxic, not quite as good as rubbing it with grass, expensive, (I could go on, but I'd start swearing Laughing ) then that's just fine. It does sort-of work. After a fashion. If you're patient. I had much more success with a wire brush in a drill though. Less mess too.
If, on the other hand, you liked the old stuff - the kind you didn't even have to open the tin and paint would fall off as you walked past - then the new one will be a sad disappointment to you. (I did always wonder what paint they used on the tin as it happens, why didn't that come off??)
While we're on the subject, I've got a nearly full 5 litre tin of 'new' nitromors here if anyone wants to buy it off me? Rolling Eyes
Alternatively, wait a little while, then bring it to me and I'll blast it for you... Discount for forum members Wink
Funnily enough, I never liked the old Nitromors stripper, but I was young & impatient. It was very smelly, heavily solvented, but never seemed to do much.
This Wickes stuff seemed very good, but I'm a bit older, more patient, more willing to put in the extra work & my expectations were probably a lot lower. Also I was coating stuff up & leaving it over night.
None of it works miracles though, none of it ever has IMO, which ever way you go it involves work & elbow grease. A good wire brush attachment for a drill (personally I wouldn't use an angle grinder one, they're just too fast & dangerous a machine) would help a lot.
How I'd love a blasting cabinet though I love you .
A good reason for using stripper is the lead content in old paints, although I always thought you had to actually ingest lead to get lead poisoning (another reason why the greens got it wrong with unleaded petrol Laughing ), still not a good idea to be around the stuff, take care folks.
Steven, are you sure that mag flange can't be turned round? Have you dismantled this mag yet? I'm pretty sure it can be done, as the Wico was used on many different engines, loads of them using that flange mounting.
Post by sjs205 on Thu Jul 19 2012, 21:37
[quote="nutgone"]
I have started pulling it apart... but I'm stuck removing the plate under the spring with the little arm on it... the photos are uploading and I will post one shortly...
But it doesn't look good fitting to my engine... from what I can work out I could rotate the mount 180 deg... but will be exactly the same!
sjs205
Post by pauldg on Thu Jul 19 2012, 21:45
I already have a 5'x2'x4' upright cabinet - just need to finish the shed to put it in - and the compressor to drive it... Nicely, when you set them up right the lead paint isn't an issue - still have to use the right media though.
You do (or did) ingest the lead in petrol if you think about it, the bulk of it passed through the engine and into the atmosphere, there it either sat on plants and leached in or went up into the sky, came back down with the rain and then went in that way - then either you (or the animals) eat the plants. Et voila, lead for dinner. I'm far from 'green' most of the time, but I always thought lead in petrol was a bad idea, design your engine properly (like they used to) and there's no need for it.
With that mag, I've seen them with both integrated and bolted flanges, so it could be either - if it's bolted you could always turn it a bit and drill new holes. If it's an integrated one, make up an adaptor plate? I'll admit making up stuff isn't original, but then you don't appear to have the original parts so that'll never happen anyway. Just my opinion on that.
pauldg
Post by sjs205 on Thu Jul 19 2012, 22:20
I had considered drilling some more holes in the bracket, I am hoping that I could get away with just too if I shifted it one hole to the right but I can't get it off at the moment. It looks like it should come off as it does have mounting bolts.
The problem I'm having is the plate that carries the centrifugal arm won't budge, would this be a tapered shaft?:
And what does the centrifugal arm actually do?
Do manuals for these mags exist?
Cheers,
Steven
sjs205
Post by hob on Thu Jul 19 2012, 22:33
i never had to take mine apart in there so i can't really help with that
however it should be what is known as an impulse mag meaning when the shaft turns slowly you should heat it click ...........this is a built in mechanism that retards the spark at slow speeds to make starting easier ..........when the engine speeds up to normal running speed this stops happening. i'm guessing that somewhere inside there must be some centrifugal weights in there that operate the impulse.??
Post by nutgone on Thu Jul 19 2012, 22:42
It's really designed to give a stronger spark at slower starting speeds, as it kind of flicks the mag round, without it you'd need to turn the engine a lot faster, but it should work without it, as I've seen these mags fitted without them.
These mags are very popular, & there are service books available, try looking on Stationary Engine parts (is it dot com or dot co dot uk? I don't remember) They should have a manual for you. It's a Wico type A isn't it? (should be written on it anyway). They're actually very good mags, I've had a few & never any trouble. (certainly not as much trouble as I'm having with a Lucas SR1 at the moment Mad )
Here you go.....
http://www.stationaryengineparts.com/wico-series-a-instructions-1955-0.html
Last edited by nutgone on Thu Jul 19 2012, 22:45; edited 1 time in total (Reason for editing : Found link)
Post by hob on Thu Jul 19 2012, 22:53
some info here
http://www.oldengine.org/members/diesel/WicoMagneto/MagData4.htm
Update
Post by sjs205 on Mon Aug 06 2012, 10:57
Hello all,
Just a quick update. I haven't got much done so far since I never had the working space setup... I've now set up my work bench in the garden shed:
I have also stripped quite a bit of the engine down, basically, the only thing left to strip now is the gears and the crankshaft:
There is actually quite a bit of play in the bigend of this conrod... what are the tolerances?
I also noticed some scoring inside the cylinder barrel as can be seen here - brown rusted section... It is only small so I am hoping that it is alright??
Also got the gear cover off:
And that is where I'm at. I have stripped down the head too, what is the best way to get the rust of the alu head? I was thinking a drill with wire brush? I will then reseat the vales and put this back together. This is my first job.
I also still need to get that pully and flywheel off, my understanding is that the flywheel will be on a tapered shaft, but the will the pully be on a threaded shaft connecting to the crankshaft? if so, how will I get this off? I have been spraying it every day with rust penetrator:
Cheers guys,
Steven
sjs205
Post by stationary stu on Mon Aug 06 2012, 11:21
Steven when you say play on the big end is it sideways if yes it's not a problem, once you get the big end seperated from the engine and look at the shell (bearing) will you be a ble to see if it's worn or not. Can you clean the piston up and see if there's much scoring down the sides and how deep the scoring is this will let you know if the piston is ok. Best to use a glaze buster on the bore to see if the scoring is just surface marks or not, if you havn't a glaze buster use emery cloth (about medium grade) soaked in a bit of parraffin. Think that should keep you busy for a few days and you can report back with your findings.
Post by sjs205 on Mon Aug 06 2012, 11:59
stationary stu wrote:Steven when you say play on the big end is it sideways if yes it's not a problem, once you get the big end seperated from the engine and look at the shell (bearing) will you be a ble to see if it's worn or not. Can you clean the piston up and see if there's much scoring down the sides and how deep the scoring is this will let you know if the piston is ok. Best to use a glaze buster on the bore to see if the scoring is just surface marks or not, if you havn't a glaze buster use emery cloth (about medium grade) soaked in a bit of parraffin. Think that should keep you busy for a few days and you can report back with your findings.
Yes the play is sideways on that Bigend. I'll get some pictures one I get it off and have a look at how worn it is.
I'll give the piston a good clean tonight but I don't think it is so bad... I think this damage could have occured perviously... the patch that you see on the cylinder barrel is a small recessed section, I think you would need to take quite a bit off with the glaze buster to get at it Wink The patch is quite low down the cylinder barrel, I would guess that the rings would be on it towards BDC
I will give it all a little going over with some emery cloth tonight and let you know how I go...
sjs205
Post by stationary stu on Mon Aug 06 2012, 12:15
The recessed section should be ok if it's when the piston is near the bottom of the cylinder but if it's higher up you could loss some compression and give the engine back pressure. Good luck tonight and hope it's all good when you inspect/clean it up.
Post by nutgone on Mon Aug 06 2012, 12:33
I did write a reply to this thread today, but it seems to have disappeared. scratch
I included a link to a gib-key puller, for the flywheel, will have to see if I can find it again.
Post by sjs205 on Mon Aug 06 2012, 12:36
nutgone wrote:I did write a reply to this thread today, but it seems to have disappeared. scratch
I hate it when that happens... I always have to copy my post content before pressing send just incase it crashes...
That info sounds like it could be of help, so if you could find it again it would be most appreciated Smile
sjs205
Post by nutgone on Mon Aug 06 2012, 12:49
Right, basically I said that if you don't really need to remove the flywheel & pulley then leave them be, as it's a bit of a job getting them off.
The pulley looks to be on a keyed parallel shaft, it should have a grub-screw or bolts to the flywheel (which I don't see) to secure it, you'll need to release whatever it is before attacking it with a puller, but be prepared, it could be a long job.
I think the flywheel is also on a keyed parallel shaft, but it is secured with a gib-key. You can get pullers for these, there's one for sale HERE, but I don't know if it will fit your engine.
Once again I would advocate GT85 as an easing/penetrating liquid, although whatever you use it'll likely be a long job. I personally have never removed a gib-key, I always left them well alone. I've heard all sorts of tales of them snapping off & needing to be drilled out etc etc, but that's usually on larger engines.
I also asked if your big end play was side-to-side along the shaft, in which case it's fine. Personally I wouldn't disturb the big end either.
The cylinder I would hone, with a good hone & some honing oil, if these aren't available I would simply use some wet & dry paper (same sort of thing as emery, just cheaper & made of paper instead of cloth) possibly with some WD40, or paraffin or diesel or something to give it a bit of lubrication. It doesn't look bad to me, especially if that mark is low down the cylinder.
these engines weren't exactly built to the tightest tolerances, they can take in a fair amount of wear without effecting running too much.
Hope this helps.
Post by sjs205 on Mon Aug 06 2012, 12:52
I've done a little research, is this the gib key that I need to remove? and is that key seperate from the internal threaded hole you can see in this picture, that is, there are three different parts in the picture: gib-key, center threaded section, and the actual pully?
sjs205 wrote:
sjs205
Post by nutgone on Mon Aug 06 2012, 13:02
No, that's just a parallel shaft key, I'm not sure whey there's a threaded centre to that shaft, maybe for a special puller.
There should be a grub screw holding against that key, threaded into the side of the pulley. Is there a little hole in the pulley (the bit the belt lays on)???
The gib key is the one on the flywheel, you can see it in one of your other pics.
Post by nutgone on Mon Aug 06 2012, 13:08
Gib key was in your final photo of that post.
Post by pauldg on Mon Aug 06 2012, 13:24
Most gib keys with a tang shouldn't have or need a retaining grub screw, they are tapered and fixed by friction. A lot of the time, someone will fit a tanged tapered key into a parallel slot as they think the head on the original is missing because it's broken.
A gib key puller is (or was) a standard service tool - that's why so many of them fail when trying to remove rusty and seized keys... That job is beyond what they were actually designed to do.
pauldg
Post by pauldg on Mon Aug 06 2012, 13:27
After what I just said, the key in that pulley could be a gib key with the head missing! I can't see much evidence of bolts or grub screws in any of the photos.
pauldg
Post by nutgone on Mon Aug 06 2012, 13:34
pauldg wrote:After what I just said, the key in that pulley could be a gib key with the head missing! I can't see much evidence of bolts or grub screws in any of the photos.
Could be. In which case it'll be even harder to get that pulley off. I would expect it to be a simple parallel affair on the pulley though. I suppose there's a chance someone jammed it on there without a grub-screw. I've seen that done before (& worse).
Post by nutgone on Mon Aug 06 2012, 13:41
Looking at it again, it could be a gib-key with the end deliberately cut off. If it was a gib-key it would've been left sticking out quite dangerously, so could well have been chopped off.
If that's the case then surely pushing the pulley on a bit (& there's only a bit of clearance) could free it up a bit.
We'd need to know there's no grub screw in there first though, to know for sure.
Think I'd still be inclined to leave it be, if it were mine. I know it's nice to get these things apart, I'm one of the worst for getting the dismantling bug, but sometimes it's best to leave well alone, clean it up as best you can & get some paint on it.
Post by nutgone on Mon Aug 06 2012, 13:45
Also, I wouldn't personally use a drill powered wire brush on the ally head (which was mentioned earlier), they're a bit harsh for aluminium. I would do it by hand. You can get aluminium coloured high temp engine paint, if you want to make it look really smart (a little OTT, IMO. Especially as it's covered in cowling) but it should come up quite nice with some elbow grease & a normal hand wire brush.
Whatever you do with it, be very careful with the head gasket joint faces. These should be cleaned up very carefully. Head joints are very important, heads should never be separated from barrels with ANY type of lever between the faces & a head gasket always goes on dry, never with any gasket jointing compounds, grease, oil or anything else.
You shouldn't have any trouble getting a new head gasket for this engine, unless the one which came off it is OK. If it's a solid copper one it can be annealed & re used quite easily, saving a few quid. But I expect it's a composite gasket.
Post by sjs205 on Mon Aug 06 2012, 13:50
I think I would agree, I don't remember seeing any holes in that pully, the only thing I could see is that parallel gib-key thing that sticks out the front...
With the head missing? what do you mean by that?
So I guess the way to get the pully off would be to remove this key buy pulling it with some sort of puller or wedge?
sjs205
Post by pauldg on Mon Aug 06 2012, 13:55
A brass wire brush 'should' be ok if you don't get carried away with it - don't use a steel one...
A tapered gib key is sort-of 'L' shaped, the bottom of the 'L' being the head - this would usually give you something to put the puller behind (it's actually more of a 'pusher' but hey).
If there is definitely no retaining bolt or grub screw, the 'best' way (other than push the pully on a little more as nutgone said - but that would need the shaft behind to be clean enough to allow it to slide) to get that out would be to weld a bolt or something to it - it'll give you something to hold on to and the heat from welding will also help to release it.
If it were mine, I'd want to get it off.
pauldg
