stopping an engine from shaking whilst running
Post by RAB on Fri Sep 25 2009, 16:03
hi what can i do to stop pink ladys duetz shaking all over the place, its on a 4 wheeled trolley and shaking alot on the axles
Re: stopping an engine from shaking whilst running
Post by Avandriver on Fri Sep 25 2009, 17:12
Make sure it is level
chock the wheels
increase the speed a little so it is smooth
try Strapping the front and back wheels together with a bungee rope
Or failing all that stick it in your lorry and fetch it northwards for me to play with
Avandriver
Post by JONESEY on Fri Sep 25 2009, 20:56
Buy the sound of it I would say the timing was out on it, or tappets to tight.
You can get Diesels to run nice and smooth
its funny
Post by RAB on Sat Sep 26 2009, 02:24
JONESEY wrote:Buy the sound of it I would say the timing was out on it, or tappets to tight.
cause on the concreate it runs sweet on grass it goes nuts cheers
Post by JONESEY on Sat Sep 26 2009, 07:26
That is strange its normaly the other way round, try fitting rubber tyres see if that helps.
Or you fit it on Rubber mouintins.
Chris Smile
Post by Avandriver on Sat Sep 26 2009, 10:46
Thare is your answer then
If it is ok on concrete ( it looked steady in the video )
then the grass must not have been level
Make sure it is level and then place some squaure pieces of plywood under each wheel to stop it sinking in the damp Cornish earth .
If that dont work I will drive to Carnon downs and take it away for you
Steve
Avandriver
Post by Lister John on Sat Sep 26 2009, 14:52
ryan wrote:hi what can i do to stop pink ladys duetz shaking all over the place, its on a 4 wheeled trolley and shaking alot on the axles
Answer is: Sell it to me! Problem solved :bartmoonie:
Lister John
why does everyone want this engine
Post by RAB on Sun Sep 27 2009, 14:52
i have had about 4 people say they want this engine, she ran all weekend didnt even had to fill the tank, an amazing engine, i strapped the wheels together in the end, worked a treat cheers
Post by JONESEY on Sun Sep 27 2009, 15:39
What did you expect it is a German engine they are excellent enginers Smile
Chris Smile
Post by Guest on Wed Oct 07 2009, 13:10
you need to reduce the amount of slogger the trolley has, things like loose wheels and mounting brackets amplify vibration, and sometimes reducing speed can help, but not soo much that it starts to lump.
