LISTER A WATER SLIDE TRANSFER SET
Does anybody know if the water slide transfer set for a Lister A is them same set as a Lister A Junior? These are the only ones I seem to be able to get.
I spoke to the guy @ Stationary engine parts and he said it was the same set. He said there are only two versions Tank cooled or Hopper Cooled I just want to make sure I am going to put the right ones onto my Lister A.
BRASSO- Life Member
Re: LISTER A WATER SLIDE TRANSFER SET
Yes thay are the same make sure you get the right rotation arrows for your engine
i sold a set of A transfers
about 6 months asgo for £3, water slide are the best, hate the ones you half to varnish, right pain in the ass, at least on water slide you can make a very small correction if needed
Hi Guys,
I received my water slide transfer set yesterday.
I just want to check a couple of things with you.
It has one large Lister Junior Sticker. Do I put this on my A, as it is not a junior??
Also does anybody have a list of dimensions of where the exact positioning of these transfers should be??
The last two sets I purchased for my lister D's had dimensions of positioning, but this set does not have any.
Any help would be appreciated.
cheers
cheers
BRASSO- Life Member
what id do martain
is google lister A pictures, and try and copy what others have done see this photo i doe this without and measurements, mind you first time around i got the 2 head stickers wrong way around and had to buy new ones lol
''The Junior'' is the generic name for the A & B type engines... so I'd put it on.
Hope and Crank- A credit to the forum
» Lister D water drain tap
» Lee Howl 6x5 Water pump & lister CS
» Jap and Lister Water Pump
» Leak in lister D water jacket
» Lister Water Pump
» Lister Water Pump
