Ruston Hornsby Pt Mag drive gears
I have recently got a new project; a Ruston Hornsby PT with a Lucas RS 1 Mag on it. The piston is free but the mag wasnt turning. Upon removal of the drive gear plate i can see there are teeth missing off the gears! Can anyone help with spares or where I can get some new ones made?
Many Thanks
Many Thanks
bones95- Posts : 2
Re: Ruston Hornsby Pt Mag drive gears
is there a number on the cog as i have a couple of mag gears of sr1/rs1 mags for ?????? enginesbones95 wrote:I have recently got a new project; a Ruston Hornsby PT with a Lucas RS 1 Mag on it. The piston is free but the mag wasnt turning. Upon removal of the drive gear plate i can see there are teeth missing off the gears! Can anyone help with spares or where I can get some new ones made?
Many Thanks
Thanks for your reply.
I will strip it down and look at them. There appear to be three gears, one crank side, a larger one in the middle and then the mag gear. It is the one in the middle that is missing teeth and cracked. I am new to stationary engines, I usually work on Massey Ferguson tractors - much simpler!
bones95- Posts : 2
bones95 wrote:Thanks for your reply.
I would rather say that stationary engines are much much simpler than tractors , used to have a fergie took over a year to restore and a engine .... well can do it in a month if work on it most spare time .
i believe the gears are the same as a WD woselly , ask matt h he may be able to fill you in .
matt i thought the same as you as, ive heard it on the rallys that a number of the wolseley wd series and the ruston pt shared some parts with each othermatt86 wrote:bones95 wrote:Thanks for your reply.
kevjhnsn wrote:matt i thought the same as you as, ive heard it on the rallys that a number of the wolseley wd series and the ruston pt shared some parts with each othermatt86 wrote:bones95 wrote:Thanks for your reply.
you are right there kev
i do have some random info in this brain of mine then
the pt are a far quiter engine when working and ticking over ,
is it the bigger water hooper on the wolseleys acting as a BASS CANNON
kevjhnsn wrote:matt
wd's are quiet engines they were designed for the sheep farmers on sheering machines
Quite a few myths appearing in this thread:-
The mag drive gears on a PT are NOT the same as on a Wolseley. Additionally you need to be aware that there are two sets of gear trains for the mag drive, depending on which mag is fitted. A Lucas mag is driven at camshaft speed whereas the Wico mag is driven at crankshaft speed.
The WD was not designed for Sheep shearing use but as the letters say WD for War Department.
Bamfordlad- Expert
the mag drive on the PT and the WD are completley different
PROPER JOB
Matth92- Life Member
Matth92 wrote:the mag drive on the PT and the WD are completley different
thanks for that matt ... i got told a year or so ago that the majority of the parts was the same as the wd ...
» Ruston and Hornsby PT mag drive gear
» Ruston & Hornsby 9PB
» Ruston Hornsby ID
» Ruston Hornsby PT
» Ruston Hornsby ID
» Ruston Hornsby PT
