timeing help please
timeing help please
Post by Diddy on Tue Oct 09 2012, 01:39
just got a villiers marvel centenary engine in a deal.
iv started to strip it down.it was only after i took the fly wheel off i rembered that i haddent put any mks on fly wheel or or back plate.
so if any one could help me out on the please i would be greatfull.
thanks dave
Re: timeing help please
Post by JONESEY on Tue Oct 09 2012, 06:58
Trying to rush a good job, I have started taking photos before stripping things down on my phone. Very Happy
I normally go to strip something down you have it in your mind I must mark this and that ,than as soon as you put the scanners on it and things start coming off you get carried away and before you now it its striped down Laughing Laughing Laughing
Sorry Dave can't help you on timing but some clever chaps will now on here
Post by matt86 on Tue Oct 09 2012, 10:36
Dave i assume you are talking the ignition timing ...?
sounds like it to me ... cant you get the engine just before tdc on the induction stroke around 1/8 of and inch and set it so the points are just starting to open there ....? as its a villiars with a back plate you will have to do a trial by error method if not dave it make a good door stop lol! lol! lol! lol!
Post by kevjhnsn on Tue Oct 09 2012, 14:36
matt86 wrote:Dave i assume you are talking the ignition timing ...?
matt your about spot on with your method mate
i set the 2 and 4 stroke villiers between 1/16-3/16" before the piston is top dead dont do the 1/8-3/16" with the the flywheel as it will be a mile out of time "been there done that with the first one i did " Embarassed lol i find that 3/16" works the best the biggest of times.
hold the flywheel on its marks and set the piston as above by turning it in a clockwise direction ,i use a pair of molegrips to stop the crank turning while you tighten the flywheel up ,or else you need 2 pairs of hands
Post by Diddy on Tue Oct 09 2012, 16:18
thats the trouble kev thers no mks on it wot i can see off so its a case of trial & error me thinks.
cheers guys.
Post by kevjhnsn on Tue Oct 09 2012, 19:53
is there a line in the flywheel ,flywheel nut and crankshaft end ,so times they are marked up like this and a long line on the outer flywheel edge
is this so on yours mate
Post by Diddy on Tue Oct 09 2012, 22:33
had a good look at it all nothing.
