My Petter AV1
My Petter AV1
Post by Biggusdannus on Fri Oct 19 2012, 11:43
Hi all, as some of you already know I picked a petter up at morval rally (aug bank hol). From the information I have gleaned from the net this is a series 1 engine built between 46-51. The head was redesigned after this to improve cold starting.
The engine was down on compression and was a right pain to start, but after I got the 'feel' for starting it she starts quite readily and the compression has returned.
Heres a video of it running shortly after I got it
Biggusdannus
Re: My Petter AV1
Post by Biggusdannus on Fri Oct 19 2012, 11:49
So as you can see above the Petter wasn't running that well and was over fuelling. I remedied this by changing the spring on the pump to a lighter one. The second video I took was with the tank connected up. She had settled down to 8-850rpm with alot less smoke! I have since decided that an 8 gallon water tank is abit on the large side and opted for a 5 gal one instead.
Biggusdannus
Re: My Petter AV1
Post by Biggusdannus on Fri Oct 19 2012, 12:03
I decided to fit the petter to my workshop trolley (temporarily) and plumb the 5 gal tank up and put together a makeshift stand. This is so I can take accurate measurements for the stand on the new trolley. Any way I put it all together and thought i'd add the pump to give the petter something to do, the pump puts a nice load on the petter due to having 2 impellors.
Biggusdannus
Re: My Petter AV1
Post by Biggusdannus on Fri Oct 19 2012, 12:06
I decided to add my little generator to the trolley yesterday and do a night time video of it running. My garage is on the road and after I'd finished filming I turned around and a crowd of onlookers had gathered behind me!
Biggusdannus
Re: My Petter AV1
Post by kevjhnsn on Fri Oct 19 2012, 13:27
well done there mate
looking good indead there, i like it very much
isnt it a great feeling when the plan starts to come together
Re: My Petter AV1
Post by stationary stu on Sat Oct 20 2012, 09:21
Well done you've done a great job at sorting your engine out. Once sorted it does run nice a steady and works well under load, you must be pleased with yourself getting your engine running so good.
I was wondering how many engines you fit in your Porsche when going to a rally Laughing Laughing Laughing nice car Very Happy
Re: My Petter AV1
Post by Biggusdannus on Sat Oct 20 2012, 10:49
Thanks, I am very pleased with the Petter considering it was running rough as rats when I got it. The boxster only has room for it's own engine and maybe a brigs and stratton (if you're lucky) lol Dan
Biggusdannus
Re: My Petter AV1
