Asbestos ???????
Asbestos ???????
Does anyone know if the filter inside the water hopper on a wolseley is made of asbestos, this is the filter that can be seen by removing the water inspection cover.
Re: Asbestos ???????
ryan wrote:Does anyone know if the filter inside the water hopper on a wolseley is made of asbestos, this is the filter that can be seen by removing the water inspection cover.
news to me that a wolseley had a filter in there, but i would not have thought it would be, asbestos was really used for filtering, though if you want to remove it, wet it fully and remove it carefully, then wrap it up and dispose of it.
There is no filter in the water chamber
You have probably got a large piece of rubber the same shape as the cover plate instead of a proper shaped gasket
Steve
Steve
Avandriver- Expert
yeah if your talking about the side casing on the wolseley the 2 square ones my are rubber ones as well
marcus- A credit to the forum
