Lister LD1 original Pumpset
Picked this little beauty up the other day, its a Lister LD1 driving a Godwin OHO pump, all on its proper base, the farm I picked it up from had it installed in 1952 by Shutes of Honiton, and it had not run since 1980 until I got my mitts on it, I dont think the pump has ever been used, no trace of oil having ever been in the sump, and no sign of the belts for it anywhere either, engine runs very nicely:cheers:
PROPER JOB
Matth92- Life Member
Re: Lister LD1 original Pumpset
well the diesel weisels are coming out in numbers latly
well i said i would never buy one ,and there went that saying
looks a nice little set up matt
the lister / petter diesels and villiers ones to and maybe others to
if there difficult to start cold a squert of oil in the inlet side works a treat
ive seen a petter paz1 dragged out of a shed and not run for yrs ,oil can pump pump gave it a swing and away it ran
i also like the pump on this set of yours there matt , it does look old but not much sign of use from the shinny shaft and as you say pulley looks well also mate
Nice find. I've been spreading the word with farmers in my area about any old engines lying around. Hopefully I'll find something like this.
I recently got myself a diesel as well, once you get them going they are great, no magnetos or spark plugs to worry about
Nice find Matt and a good price, so are you leaving it as it is and belting the pump up and showing them together?
Kev I've never heard of a squirt of oil into the inlet to help start a diesel before, a squirt of either (eazystart) or a flaming rag next to the inlet is very good to start diesels.
Ian no mags or spark plugs but you've got fuel pumps and injectors the non spark alternatives
I'm kind of hankering after a Diesel myself now. I like the simplicity of no spark plugs etc etc, but they still have their problems, which mainly consist of fuel system bleeding (simple really, don't let it run out of fuel).
This one looks a nice little set up, I especially like the look of the pump. I reconditioned a Lister LT2 for my uncle when I was about 16, he used it to power his narrow boat. I remember being quite surprised at how clean they are inside.
As for the oil in the inlet, Ian's little Petter AA1 has a small oil primer on the rocker box, this squirts some oil onto the valves/rockers & seems to help cold starting. I can only assume Kev's similar trick helps the piston get a good seal, therefore giving better compression, whilst also giving the engine something else to burn (as engine oil burns slower than Diesel this may also help a bit???)
I know Ian sees his Diesel as a possible "end of world" engine, or useful if the power was to go out for a lengthy period, but I don't think a Diesel is necessarily the way to go in such circumstances, as you still need to find fuel of some sort (veg oil, kerosene, heating oil etc etc).
BUT, if you had a petrol engine you could run it off of gas. You can make your own gas from wood, coal or charcoal & water vapour. So I think I might be making myself a small wood gas generator over the winter (if I get time) & see if I can't get my own "End of World" engine set-up.
I still want a Diesel of my own though.
» Lister LD1 & Godwin Pumpset
» Original Lister D
» Original Lister D
» My first project Villiers C12 Simplite Mk4 Pumpset
» Original Lister D
» Original Lister D
