Crank bearings
Crank bearings
The crank bearings in my wolseley look ok, but is it worth me changing them while ive got the flyweels off.
Re: Crank bearings
Was there any play in them are they nice and smoth running if the answer is yes to both .
Then No you will be wasting your money, you will never be working the engine like it was built for
Re: Crank bearings
Yep, as Chris Says, if vertical float is minimal (the maximum allowable tolerance will be in the manual) then leave well alone, sideplay as in (in and out) is corrected in most engines with shims, and i dont think your engine will be any exception.
» Lister DK Remove Crank bearings/Shaft.
» First lister D, and first time everything else in old engines.
» Vintage Oil and Bearings
» Bearings size
» Petter main bearings
» Bearings size
