Villiers Mk10 sump removal
I have undone the 4 bolts holding the sump on but it won't separate from the crankcase. It looks like previous owner may have used a sealant instead of the proper gasket. I don't want to wack it too hard incase I break something. Any ideas? Or, do I not worry about getting inside? It would be good to clean the black residue out though. I have some new parts coming - condenser, HT lead and air filter but still haven't found a fuel cap:(
Greg
Greg
Last edited by bluedog on Mon Nov 26 2012, 12:00; edited 1 time in total (Reason for editing : typo)
bluedog- Born to be wild
Re: Villiers Mk10 sump removal
It should come off at that Greg, nothing else holds it. I would remove it as they tend to collect a lot of cr*p and sludge in there, there is also an oil trough for the con rod dipper that gets clogged. I would use a piece of wood and a hammer etc and just keep hitting it evenly, they are quite tough if you hit them on the corners.
clamp the sump to a hevy table or wood you can stand on and wiggle it until the seal starts to break away
then lift it block up striegt and then lie it on its side "reason as follows as like FODEN PETE says above and more,
if still not playing the game :-
i use a stanley blade or steel ruler, and cut it apart the rest, as the dipper on the bottom of the conrod is very easy to snap off, and some of the sumps has the dipper tray fixed to the sump and not to the block so as to protect the alloy dipper on sump removal
Thanks for the tips. I will give it another go tonight. Is the gasket paper or other material?
Greg
Greg
bluedog wrote:Thanks for the tips. I will give it another go tonight. Is the gasket paper or other material?
Greg
Just paper Greg.
Foden wrote:bluedog wrote:Thanks for the tips. I will give it another go tonight. Is the gasket paper or other material?
Greg
Just paper Greg.
greg
true true pete
just thin paper less than 1/2mm or 0.5mm max,no cereal boxes here to low to oil and will ozz it out ,and lift your paint away
Picked up some gasket paper today. can anyone advise what thread the bolts holding the fuel tank straps are or should be? I have a couple with stripped threads.
Greg
Greg
» Villiers Mk10 sparkplug removal problem
» Villiers Mk10 - Repaint
» Villiers Mk10
» villiers mk10
» Villiers Mk10
» Villiers Mk10
» villiers mk10
» Villiers Mk10
