A Wolseley at last!!!!
+5
9 posters
Page 5 of 9
Page 5 of 9 • 1, 2, 3, 4, 5, 6, 7, 8, 9
Re: A Wolseley at last!!!!
Getting on now, bit by bit, been getting some ear ache over it from wife though so been a little held back
With suspicions noted I filled her with watter tonight, as I suspected the water jacket cover plate leaked the inside face of the cover is heavily pitted and on further inspection has low spots on the gasket face on 2 sides. For now, in my early prep for an upcoming run (I hope), I have flipped it over so that the smooth outside face is now the gasket face and there are no leaks. I may cut a new cover later but for now I may just fill the face and paint it
blackvanman- Life Member
Thats a common problem Andy .
In the end i just made a new plate for mine .
matt86 wrote:Thats a common problem Andy .
Yep, it will probably happen when I find a bit of plate, been out there again, still holding water for now, but that could all change with a little heat.
Andy in trouble with her in doors that's going to cost you big this Christmas.
Can you not get away with 2 gaskets on and some silicon instant gasket until you make a plate later in the year. Com'on stop messing and get her started.
was considering that Stu, but decided there was probably more merit in flipping the plate over for now (plus I won't have to clean the silicone off).stationary stu wrote: Andy in trouble with her in doors that's going to cost you big this Christmas.
Still holding water this morning, tank on, line on, cut gasket for round cover and fitted, dragged her out into the air......
half hour of winding over, puffs of smoke, back pops, flames from the exhaust port, 3 buckets of sweat and a re-coup at kfc with the little man.
First real observation is I need a trolley lol, have the wood here ready just need to sort some wheels so watch this space , once I have the trolley sorted she won't be trying to spin on me as I turn her over , then I'll get a second pair of hands on board as two nutters cranking is better than one Then I can go through everything (mostly the timing) one step at a time and only be half as knackered
Still, its all progress:
Can any body please tell me how many turns out their speed adjuster is set?
It never made much difference with my old one, but it's far too long ago for me to remember where it was set.
it seems strange to me, these were always such easy starters, it was probably our easiest starting engine, along with the Tarpen (the Douglas was always a complete & utter bitch).
I think you'd be right to double check the timing. it's supposed to be 2 strokes which are difficult starters, I've just had my Scott down to the last nut & bolt & it started 3rd pull!
(sorry, don't mean to rub it in )
The mag should 'impulse' when the crank keyway is at BDC, just turn the speed screw about halfway in (or out) which should enable it to run. Wolseley's and Ruston PT's can be sods to start if they dont go straight away, they flood easily and then they never will start until they dry out. I now just fill the float chamber and then turn the fuel off until the engine fires up, saves a lot of mither with the things! Have you tried a new short reach plug as I have had a couple of duff ones straight from the packet?
Foden wrote:The mag should 'impulse' when the crank keyway is at BDC, just turn the speed screw about halfway in (or out) which should enable it to run. Wolseley's and Ruston PT's can be sods to start if they dont go straight away, they flood easily and then they never will start until they dry out. I now just fill the float chamber and then turn the fuel off until the engine fires up, saves a lot of mither with the things! Have you tried a new short reach plug as I have had a couple of duff ones straight from the packet?
Hi Pete,
had a b6hs in there, swapped it out for a long reach BLN as the short reach was 1/2" up the hole, if anything she did pop and flash more with the long reach (I know that the long reach won't clash due to looking at it when head was off). Yes she does impulse at TDC (keyway bdc). Will bash a trolley up and let the hole in my finger improve then have another crack at her
Andy
It's always easier to fit the engine on to a trolley even a temp one makes life a lot easier and the engine will stat where you want it. I learned the hard way when I was messing with a Lister D in the shed it started a lot easier then I'd expect it too and tried to hop out of the shed.
It does sound as if you need to check the timing out and rather then swinging as fast as you can see if you can use the impulse to get it to fire.
May be a case of belting it to another engine until you have it sorted.
The short reach plug SHOULD be halfway up the hole Andy! It is like that to help prevent fouling.
From what I can find, wd 1&2 should be short reach, and wd8 should be long reach stationary parts list a b4h 12.5mm reach for wd 1&2 and bpr6es 19mm reach, for wd8, can anyone confirm with another source?Foden wrote:The short reach plug SHOULD be halfway up the hole Andy! It is like that to help prevent fouling.
As far as I know, the head is the same on the wd 2 & 8 (1 being smooth hopper).
Ah sorry, thought it was a WD2 you had!
ah ok, do you by any chance know why the plug change even though the head are (I believe) the same?Foden wrote:Ah sorry, thought it was a WD2 you had!
Andy
Andy I'll try to remember and see which plug I have in my WD8.
got 5 min to myself tonight, went through the timing, note to self, just because the impulse goes clang at tdc, doesn't mean somebody hasn't played with the points cam!!! DOH!!!!!! it was firing a bit before bdc!
will try for a run again tomorrow, but will probably stick her on a trolley first
blackvanman wrote:got 5 min to myself tonight, went through the timing, note to self, just because the impulse goes clang at tdc, doesn't mean somebody hasn't played with the points cam!!! DOH!!!!!! it was firing a bit before bdc!
Personally I've never liked timing engines to the impulse, always either jam it up for timing or wind the whole thing backwards & time it that way.
nutgone wrote:blackvanman wrote:got 5 min to myself tonight, went through the timing, note to self, just because the impulse goes clang at tdc, doesn't mean somebody hasn't played with the points cam!!! DOH!!!!!! it was firing a bit before bdc!
ah, now you see the manual tells you how to time her up by bringing the keyway uppermost (bdc) then wind the impulse to the stop then back from the stop until the dogs line up, I did that but failed to do the next step (by wrongly assuming that as I had not touched it, nobody else had) which is to then confirm the timing by checking that the points just begin to open at tdc
Oh well, you live you learn
With the one i had i timed it up by the manual , and i timed it up 1st time no problem , its over 2 years ago now so dont ask me how to do it ... If you need me to have a look for the book i can .
matt86 wrote:With the one i had i timed it up by the manual , and i timed it up 1st time no problem , its over 2 years ago now so dont ask me how to do it ... If you need me to have a look for the book i can .
got the manual on pdf matt as above She is bang on now cheers
Errrrr, bang on is the word!!!!!!!!!!!!!!!!!
out having a smoke just now, couldn't resist winding it over now the timing is correct, sh1t me she went first flick!!!!!!
Happy bunny, unlike the neighbours probably
good news Andy , was the flick on the flywheel by hand ???
If so i am lead to believe that the rings will want replacing soon as they are not meant to be started by hand . you could do that with mine and when it was under load it started to squeak a little . Which was a ring squeak .
same with most engines are not intended to be started by hand . but American engines / open cranks is different design .
blackvanman wrote:Errrrr, bang on is the word!!!!!!!!!!!!!!!!!
Bloody good on you, I thought it was a bit odd having starting troubles with one of these, the WD2 I had started easier than any Lister D (although mechanically I think I kind of prefer the Lister D).
Lovely when one sparks back into life again.
EDIT: I just spotted the time of that last post. Bet you were in trouble for that one!
no matt, it was from the handle, I've just re-ring'd her as well remembermatt86 wrote:good news Andy , was the flick on the flywheel by hand ???
Sounds a bit weird to me, why shouldn't you start an engine from the flywheel by hand? I'd be interested to know the mechanical/scientific explanation
Blimey, well past 1 in the morning and you go starting engines Andy! Still, at least now you know she goes, well done
here's the very quick vid I took, yes I do know there is not enough water in her, it was only a small amount for testing I put in the other day
http://www.flickr.com/photos/82040255@N08/8314296296/
Page 5 of 9
