lucas sr1 implulse
lucas sr1 implulse Empty lucas sr1 implulse
Post by blackvanman Wed Nov 28 2012, 20:19
ok got me a wolseley as per:
http://www.stationaryengineforum.net/t5880-a-wolseley-at-last
one other thing I picked up on is the impulse on the lucas sr1 mag doesn't work, anybody know how they work before I pull it apart? Very Happy
lucas sr1 implulse Empty Re: lucas sr1 implulse
Post by Foden Wed Nov 28 2012, 20:57
Sometimes they just need lubricating, the one on my Petter didn't work so I kept spraying WD40 or similar into it and eventually with rotating it the mechanism freed off. There is a coil spring and a couple of weights inside and the weights get stuck up with congealed oil that lodges there. Earth the HT lead when you spin the mag or it could damage the coil.
Post by blackvanman Wed Nov 28 2012, 22:01
Foden wrote:Sometimes they just need lubricating, the one on my Petter didn't work so I kept spraying WD40 or similar into it and eventually with rotating it the mechanism freed off. There is a coil spring and a couple of weights inside and the weights get stuck up with congealed oil that lodges there. Earth the HT lead when you spin the mag or it could damage the coil.
Nice one Pete, good heads up with the coil spring, it would have got me Very Happy
Post by jay Fri Nov 30 2012, 19:43
and if you decide to remove the end moving bit on the mag be careful as the spring is strong and can send bits flying into the deepest of dark places in a workshop/garage/lounge..and they can be fun getting back together but not impossible just fiddly holding the spring in place while trying to do up the nut..
jay
Post by blackvanman Fri Nov 30 2012, 20:44
jay wrote:and if you decide to remove the end moving bit on the mag be careful as the spring is strong and can send bits flying into the deepest of dark places in a workshop/garage/lounge..and they can be fun getting back together but not impossible just fiddly holding the spring in place while trying to do up the nut..
jobs like that are best done in a small tent, or under the duvet with a torch Very Happy Watch this space lol
Post by Guest Sat Dec 01 2012, 12:10
[quote="blackvanman"
jobs like that are best done in a small tent, or under the duvet with a torch Very Happy Watch this space lol[/quote]
I think someone must have been in the scouts Laughing Laughing Laughing
Good luck and good hunting Laughing
Post by blackvanman Sat Dec 01 2012, 21:47
FUDGE IT!!!! there are no springs...........
anyone have any drawings anywhere that show the impulse and how it should look?
Post by nutgone Sat Dec 01 2012, 22:16
I spent 5 weeks touring France with a small tent, & believe me, you can still lose things in small tents! Mad
