Asbestos ???????
Asbestos ???????
Post by RAB on Fri Oct 02 2009, 11:23
Does anyone know if the filter inside the water hopper on a wolseley is made of asbestos, this is the filter that can be seen by removing the water inspection cover. cheers
Re: Asbestos ???????
Post by Guest on Fri Oct 02 2009, 13:39
ryan wrote:Does anyone know if the filter inside the water hopper on a wolseley is made of asbestos, this is the filter that can be seen by removing the water inspection cover. cheers
news to me that a wolseley had a filter in there, but i would not have thought it would be, asbestos was really used for filtering, though if you want to remove it, wet it fully and remove it carefully, then wrap it up and dispose of it.
Post by Avandriver on Sat Oct 03 2009, 17:47
There is no filter in the water chamber
You have probably got a large piece of rubber the same shape as the cover plate instead of a proper shaped gasket
Steve
Avandriver
cheers steve
Post by RAB on Sat Oct 03 2009, 17:52
that was what it was, did look like asbestos though cheers
Post by marcus on Sat Oct 03 2009, 18:55
yeah if your talking about the side casing on the wolseley the 2 square ones my are rubber ones as well Very Happy
marcus
