Richard's Ruston
Richard's Ruston Empty Richard's Ruston
Post by nortonmotors Mon Dec 10 2012, 16:05
Richard's Ruston Ruston14w.servimg.com/image_preview.php?i=5&u=17978584]Richard's Ruston Ruston14[/url]
Still to find, or make:
.fuel filler cap
.shield for starter dog/crank end
.R&H transfers
.'proper' wheels
R.
nortonmotors
nortonmotors
Richard's Ruston Empty Re: Richard's Ruston
Post by nutgone Mon Dec 10 2012, 18:20
Looking good though, very nice job on the paintwork. Very Happy
Post by nortonmotors Mon Dec 10 2012, 19:24
Not quite sure how I posted the same photo twice. Here's what was supposed to be the second.
Apart from the tank, which came already painted off eBay, the rest I did with a 3/4" brush and, after assembly, did the bolt heads & nuts with a tiny brush.
I think the tank had been sprayed, and is a slightly different shade, so I may do a brush job to match the rest of it.
nortonmotors
nortonmotors
Richard's Ruston Empty Help!
Post by nortonmotors Mon Dec 10 2012, 19:30
What am I doing wrong?
That photo is not the same as Ruston-14 in my pictures library.
nortonmotors
nortonmotors
Richard's Ruston Empty Cracked it!
Post by nortonmotors Mon Dec 10 2012, 19:45
Richard's Ruston Ruston20
Working on the 'rat-in-a-maze'/'infinite number of monkeys' principle, I think I now understand the instructions re posting photos. But then I've been wrong before ............. Crying or Very sad .
THIS is the other side of my PT, including all the smeared fingerprints not visible in the excitement that she actually runs.
nortonmotors
nortonmotors
Post by Ianhw77k Mon Dec 10 2012, 20:49
What a cracker! Lovely job you've done there mate Smile
Post by nutgone Mon Dec 10 2012, 21:30
You know what, if you used a decent high-tack primer, you could paint up those wheels. They wouldn't look perfect, but they'd pass off a lot better until you source some others. You could even get creative with a drill & small hole cutter, maybe a file, or junior hacksaw, & make them a little more interesting. Once painted gloss black they wouldn't stick out so much & would look older to the passing eye.
Although I don't mind them myself, as the whole thing looks so neat, they kind of look neat with it.
Post by nortonmotors Mon Dec 10 2012, 23:24
Thanks guys!
One thing I didn't think when making the trolley is how far I have to bend over to swing the handle.
The other thing is that I built it on the bench and had to shore up the shed roof before using a block and tackle to get it down to trolley level. Plan ahead.
Nutgone: it will probably stay with those wheels. Drilled holes and painting them is an excellent suggestion.
nortonmotors
nortonmotors
Post by Guest Tue Dec 11 2012, 12:18
Looking good Richard, if your after some wheels contact miked on the forum as he has a lot to sell and get maybe a set of 12inch and it will lift the engine a bit higher to help you start it.
http://www.stationaryengineforum.net/t5866-for-salecast-wheelsloads-of-them
I think it may be just ebay where you can source a tank cap unless someone has one in the back of there shed.
