help with climax domestic pump
Post by LJD on Sat Jan 05 2013, 21:50
Hello I'm new to the forum, and would greatly appreciate any help I am currently renovating the pump and am in need of the two brass access plugs that cover access to the lower valves they are a funny size and I cannot locate any.
Thanks in advance
LJD
Re: help with climax domestic pump
Post by matt86 on Sat Jan 05 2013, 21:54
you got more chance finding rocking horse poo!
The only way might be to get someone to make some for you , unless you wait but expect a long wait for some to turn up .
as i thought
Post by LJD on Sat Jan 05 2013, 21:58
Yes I thought this might be the case, just wondered if people had them made from scratch or turned down from a slightly larger plug, and if anyone had any contacts for either
LJD
Post by matt86 on Sat Jan 05 2013, 22:00
you would have to try a machinist / tool maker turn down from bar stock bronze / brass .
Post by blackvanman on Sat Jan 05 2013, 22:32
what do they measure accross? both thread id & od, can you guage tpi?
Andy
Post by hob on Sat Jan 05 2013, 22:56
if you have the size you might get them here
http://www.vintagecarparts.co.uk/categories/vintage-car-parts-taps-pipe-and-fittings
Post by matt86 on Sat Jan 05 2013, 23:12
there alto bigger than that. there around 1.1/4 ish
Post by hob on Sat Jan 05 2013, 23:23
matt86 wrote:there alto bigger than that. there around 1.1/4 ish
like this?
http://www.partridgeshadleigh.co.uk/hardware/plumbing/plumbing-fittings/connectors/brass-plugs
Post by matt86 on Sat Jan 05 2013, 23:41
that would work but I think it's bigger than that more like 1.1/2 . the original had a hex cut out to take a big Allen key. But it would work the same. A tpi gauge for bsp is what you need to measure it.
Post by blackvanman on Sun Jan 06 2013, 00:04
matt86 wrote:that would work but I think it's bigger than that more like 1.1/2 . the original had a hex cut out to take a big Allen key. But it would work the same. A tpi gauge for bsp is what you need to measure it.
was wondering if it was bsw being as its not a pipe fitting, if its bsp it will be 11 tpi, if its bsw it will be 7 tpi for 1 1/4 or 6 for 1 1/2
Post by matt86 on Sun Jan 06 2013, 00:30
all water pump threads are bsp on English pumps. unless it's a nut or bolt. my pumps I have got have had new drain plugs and they was bsp.
Post by LJD on Sun Jan 06 2013, 08:48
Thanks guys, pretty sure the dia is 1"1/8 because I have some plugs and 1" is to small and 1"1/4 is to big, a strange size I know
LJD
Post by LJD on Tue Jan 08 2013, 17:40
Hello again have noticed a couple of members have done these pumps before, I could do with some advice on how to get the piston out and crankshaft. I'll attach a a pic of where I'm at with it. Oh crap don't know how too!
Thanks Lewis
Last edited by LJD on Tue Jan 08 2013, 17:41; edited 1 time in total (Reason for editing : mistake)
LJD
Post by Ianhw77k on Tue Jan 08 2013, 21:19
Good plumber's merchant might be able to help you with the plugs. If you could only get pipe fittings you could still adapt them to be blanking plugs.
Post by matt86 on Wed Jan 09 2013, 02:21
LJD wrote:Hello again have noticed a couple of members have done these pumps before, I could do with some advice on how to get the piston out and crankshaft. I'll attach a a pic of where I'm at with it. Oh crap don't know how too!
Thanks Lewis
that would be me? there easy to take apart. take the head part off, held on with two bolts and a verry stuck gasket. the piston and conrod unscrew. crank, take side covers off and remove through one side, I forget which side it is now.
Post by LJD on Wed Jan 09 2013, 08:10
Thanks Matt, I thought the Conrod unscrewed but its so tight I didn't want to break anything will try again tonight
Thanks Lewis
LJD
Post by matt86 on Wed Jan 09 2013, 09:34
you shouldn't be able to break it by just undoing the conrod, it's a normal thread.
Post by LJD on Wed Jan 09 2013, 10:46
I hope not, don't want to be searching for parts for the rest of my life, these bits are like rocking horse sh*t
LJD
Post by RAB on Wed Jan 09 2013, 14:54
Have a look here as well,
http://www.amospumps.com/eolalcon.html
Post by stationary stu on Wed Jan 09 2013, 15:38
Thanks Lewis
This tells you how to download pics.
http://www.stationaryengineforum.net/t2492-step-by-step-photo-upload
Post by LJD on Wed Jan 09 2013, 18:01
Oh I see now uploading photos is easy, just need to use the computer instead of phone
Thanks Lewis
Oh and managed to get the Conrod loose, just having trouble with the brass set screws that attach the piston to the crank at the back
LJD
Post by blackvanman on Wed Jan 09 2013, 18:27
sorry off topic, but does anyone else giggle uncontrollably when they read the first 3 words of this thread on the home page Very Happy
lol! lol! lol!
Post by LJD on Wed Jan 09 2013, 18:50
Very funny, well spotted lol!
LJD
