Villiers mk15 4 stroke COIL???
Hi guys im Jon from cornwall,
I recently got given a villiers engined howard bantam rotavator, it has a villiers mk 15 4 stroke engine on, it doesnt run so ive cleaned the points, but the coil looks like the original so i was looking for a replacement but cant find one anywhere i dont know the part number for the coil for this model engine, but the ones ive seen on ebay the measurements are not the same as the coil i removed.
Anyone else had this problem? any ideas? cheers guys
jonmurley1- Posts : 1
Re: Villiers mk15 4 stroke COIL???
You need to contact either George Shead at http://www.villiersparts.co.uk/ or John Cruse at http://www.themowercentrehailsham.com/5.html they will have them in stock. Replace the condensor at the same time, expect to pay around £60 for the coil though.
Hi Jon, unfortunatly there not a cheap item to replace but you could pay half there price for a secondhand one and it be the same as the one you have, so maybe worth buying new.
Take a look at this thread.
http://www.stationaryengineforum.net/t5748-villiers-poor-spark-post-moved-to-suitable-section
» which RPM Villiers Mk15?
» new toy .......Villiers Mk15
» Dutch Villiers Mark 15
» strange problem with big end Villiers Mk15
» Villiers MK15 carb issue
