something to run.
something to run.
Post by earlsinclare on Sat Jan 19 2013, 12:04
hello everyone,
after what seems like forever I have eventually found something for my petter to run.
it is a alpha laval type 9 vacuum pump. it came with a factory made fitting bracket.
hope you like it.
Richard.
earlsinclare
Re: something to run.
Post by nutgone on Sat Jan 19 2013, 12:14
It's very compact, isn't it?
I like it, are you going to make up a milking display to go with it?
BTW, lovely job on the paintwork.
Post by stationary stu on Sat Jan 19 2013, 12:19
I was disappointed to hear it was a pump I thought you had found a super charger of a Petter A1.
Very nice looking engine with a very small pump, nice find to get a complete unit.
Post by earlsinclare on Sat Jan 19 2013, 12:23
I am trying to find a pair of lister vacuum clippers to run from it, it would look good next to my sheep shear display.
Richard.
earlsinclare
Post by nutgone on Sat Jan 19 2013, 12:28
stationary stu wrote: I thought you had found a super charger of a Petter A1.
I thought that too, when I first saw it. Laughing
Post by stationary stu on Sat Jan 19 2013, 12:30
earlsinclare wrote:I am trying to find a pair of lister vacuum clippers to run from it, it would look good next to my sheep shear display.
Richard.
It must have some power to be able to operate 2 pairs of shears.
Post by nutgone on Sat Jan 19 2013, 12:31
Richard.
I didn't even know they existed! Shocked
Is there anything else you can run off a vacuum pump? I know some car manufacturers experimented with running various things from vacuum back in the 60s & 70s. I think it was Ford who tried running windscreen wipers from the manifold vacuum, via a large storage reservoir in the wing.
Post by stationary stu on Sat Jan 19 2013, 13:11
Truck brakes used to work on a vacuum system, same idea the air system they use now but the opposite way round LOL.
Post by Hughesy on Mon Jan 21 2013, 08:23
May I ask where you got it from I'm searching for one of theseto go on my lauson (alpha sold) it as a milking pump set. But mine was gone when imported it.
Very nice find.
Post by Foden on Mon Jan 21 2013, 11:46
Richard got it off ebay Lewis, but you Lauson would most likely had an ALPHA setup like this http://www.old-engine.com/alpha.htm
I actually had a vacuum pump similar to the one on the website but the crank was damaged badly where the pulley had run loose, I put it on ebay but got no takers so it took the 'Slow Boat to China' as it was in my way. They do crop up from time to time though on ebay, but usually missing the glass oil bottle. The ones like Richard has were Alfa, not Alpha, 'oilless' pumps and normally found on Petter A's and Lister D's where they were bracketed to the front of the engine.
Post by Hughesy on Mon Jan 21 2013, 12:11
Thanks for clearing that up. When richard spelt it alpha like on the lauson engines. got me worrying i had missed the vacuum pump on ebay.
Post by glowes3 on Thu Mar 14 2013, 07:09
Right off recent discussion - but just wanted to say how good your engine looks.
I have a look around when I'm dragging my feet on a project and to see a well restored engine helps get me going again.
glowes3
update.
Post by earlsinclare on Thu Mar 14 2013, 07:17
hello,
the engine is now finished, it has a vacuum clipper running from the pump. I will take a picture of it when the snow goes.
Richard.
earlsinclare
Post by earlsinclare on Sat Mar 16 2013, 12:36
earlsinclare
Post by Ianhw77k on Sat Mar 16 2013, 13:02
What a lovely set-up, hats off to you sir. Wink
Post by stationary stu on Sat Mar 16 2013, 13:05
Cracking restoration again Richard and a nice small display built in, nice one.
Post by Foden on Sat Mar 16 2013, 14:40
That looks fine Richard, made for each other. I am still battling with my Villiers powered shearing set restoration, dragging on forever it seems, but completion date is iminent at last! Just restored some Burman horse clipper's, a lot easier as there was no engine involved. Laughing
Post by Smitty on Sat Mar 16 2013, 15:53
Richard.
I can help with that as I owned a car with one on it.
The wiper system was operated straight off the carburettor but run through a quart vacuum can first to ballance any pulses I believe.
They worked good untill you went uphill when the throttle opened and killed the vacuum!
Needless to say the application only lasted a few years and then dissapeared.
I also had a vacuum operated cooling fan on the dash which was again operated straight from the carburettor through a quart can.
The engines were both V8's and were able to carry the load, except when the foot went down to kill the vacuum.
John.
Post by glowes3 on Sat Mar 16 2013, 20:30
It's always great to get a project finished and working and that's a great example Richard.
Compact set up and looks great - everyone would be happy to own that I reckon.
Thanks for the final picture.
Graeme
glowes3
Petter A1
Post by Lewis MacRae on Sun Apr 14 2013, 15:32
You have done a stunning job on the paintwork Very Happy
