Wolseley WLB 9
Wolseley WLB 9
Post by Stingray on Tue Jan 22 2013, 17:59
HI All
Need some help please.
If you remove the carb with the butterfly valve you find another butterfly valve in the casting.
There is also a screw next to the flywheel to do some adjustment, wich only turns in surcles doing nothing.
Was that set screw on the side suppost to do something to the butterfly valve in the casting or not.
I need detail on that part please.
Raymond.
Stingray
Re: Wolseley WLB 9
Post by Foden on Tue Jan 22 2013, 19:35
With the carb removed the butterfly valve in the crankcase should move when you pull the speed control knob out by hand. If it is just rotating and nothing is moving then take the valve coverplate off and see if it is still connected properly.
The butterfly valve can get stuck up with old oil, there may be a brass screw mounted vertically above the butterfly shaft which can be removed to get oil into it. Failing that I would remove the circular plate from the rear of the engine and check that the bronze governor fork isn't broken.
Re: Wolseley WLB 9
Post by Stingray on Tue Jan 22 2013, 20:07
Hi Pete
Thank you for the speedy reply.
I have removed the valve cover and saw the speed controll set screw with a large spring and a bended metal shaped nut. Not sure what else must be there.
When I turn the speed controll screw the hole screw and the bended shaped nut turns in sircles.
I have no clu as how that section is working or how the governor works.
Thanks
Stingray
Re: Wolseley WLB 9
Post by Foden on Tue Jan 22 2013, 20:16
Well the 'bended shaped nut' as you call it should not turn, if I remember correctly it should trap itself against the crankcase, so that is part of the problem. If you pull the speed control knob and shaft outwards the butterfly should move with it, as I said it can get gummed up with congealed oil and may need working back and forth while spraying some WD40 etc onto it?
Re: Wolseley WLB 9
Post by Stingray on Wed Jan 23 2013, 18:15
Hi Pete
Still no luck. I have spraid WD40 everywear but the shaft is doing nothing to the butterfly valve.
I will have to remove the one flywheel and the coverplate to see if it is all connected at the bottom of the govener.
Not really sure of to how one remove the Gib key.
Also not sre if the shaft on top at the butterfly must be connected in a specific manner or just there to tension the spring.
Thanks.
Stingray
Re: Wolseley WLB 9
Post by Biggusdannus on Wed Jan 23 2013, 18:30
The butterfly shouldn't move when the engine is stationary. It will be fully open, once you have the side cover off you will be able to pull the governor rod to see if it moves the butterfly correctly. I suspect theres nothing wrong with it as they are quite simple.
Biggusdannus
Re: Wolseley WLB 9
