Compression
Compression
Post by RAB on Wed Oct 07 2009, 03:44
Ive left that Duetz stand for a couple of weeks now, yeasterday i went to start it, and it had lost all compression, after a thew cranks it soon came back, but is this normal, cheers
Re: Compression
Post by JONESEY on Wed Oct 07 2009, 08:48
No, have you a sticky valve, is it smoking a lot ?
Sad Chris
it smoke a little when starting
Post by RAB on Wed Oct 07 2009, 11:29
JONESEY wrote:No, have you a sticky valve, is it smoking a lot ?
Sad Chris
but then runs fine, any ideas what i should do chris, could this be a problem ????????
Re: Compression
Post by Guest on Wed Oct 07 2009, 12:59
Sad Chris
depends if putting oil into the cylinder makes a difference, in which case, could be rings or valves. when its running, the oil and fuel in the bore, and the carbon help to improve the seal, when it stands, the seal weakens as the fuel and oil soak past the rings
im getting a
Post by RAB on Wed Oct 07 2009, 15:28
im getting a little conserened about this now :alien2: :alien2:
Re: Compression
Post by JONESEY on Wed Oct 07 2009, 21:16
Put a set of rings in it, you can get things to run still if valves are sticking. When it stands just depends on were the valves are ,when I stop al my engines I always turn them over until both vales are shut
Re: Compression
Post by Guest on Thu Oct 08 2009, 12:13
JONESEY wrote:Put a set of rings in it, you can get things to run still if valves are sticking. When it stands just depends on were the valves are ,when I stop al my engines I always turn them over until both vales are shut
i agree, put new rings in and hone the bore,
Then to preserve the engine, when the engines deing stopped, turn it upto compression to shut the valves, and then you could even go as far as sealing the inlet and exhaust up with clingfilm. a little drop of oil down the bore doesnt durt either.
Paul Smile
some may not agree
Post by RAB on Wed Oct 14 2009, 14:39
but, when we was at the blowdown there was dust and grit everywere, i ran the duetz without the valve cover so people could look, i think dirt may have got into the valves causing them to jam, so i got her running again and sprayed wd40 onto the valves and good news, not losing compression now cheers
Re: Compression
Post by JONESEY on Wed Oct 14 2009, 15:56
Sounds like you sorted it Smile Smile Smile Smile
nearly had the flywheel off aswell today
Post by RAB on Wed Oct 14 2009, 16:06
making progress jonesey cheers
Re: Compression
Post by JONESEY on Wed Oct 14 2009, 21:11
You need to get your self a nice old open crank a bit of dust dont bother them :lol2: :lol2: :lol2:
Chris Smile
yeah i do want one
Post by RAB on Thu Oct 15 2009, 02:25
just dont know what to get
Re: Compression
