Petter PAZ1 Oil
+4
8 posters
Petter PAZ1 Oil
Hi there!
Today i changed my oil in my Paz and replaced it with 10w40 semi synthectic diesel oil is this ok or shall i might aswell open the sump plug again?
Thanks
Thanks
Statman- Life Member
Re: Petter PAZ1 Oil
That's fine Adam, I use the cheapest oil on the shelf in my diesel van. The only thing is I change the oil and filter ever 6 thousand miles, not sure how you'd work that out unless you have an engine hour counter fitted.
Re: Petter PAZ1 Oil
Thanks Stu!!!
Another question the Paz has alot of oil pipes outside and i was wondering is it worth it taking them off to see if they are clear of crud or just keep well clear of them?
Thanks
Thanks
Re: Petter PAZ1 Oil
That Oil is Fine like Stu said change the oil every year, when the first rally is coming around change it then.
It just keeps everything clean and helps stop smoking.
Yes take them off and flush with carb cleaner
Re: Petter PAZ1 Oil
this is the learing forum
you dont get sort of advice on the other side
well us dorset boys dont
your better off talking to yourself
dont know why thay didnt seem to say much to us????????????
mike.
mike.
Re: Petter PAZ1 Oil
mike d wrote:this is the learing forum
mike.
Its cause they stick to there own , they always did
Re: Petter PAZ1 Oil
Yes Adam I'd remove the pipes and give em a soak in engine degeaser or parafin would do as your right in saying they do fill with crud (carbon deposits). Maybe a babies bottle brush to get inside would work depending on the size of the pipes. If it's bad you could think about running an engine flushing oil in it for about 20 minutes (you'd need to check the can first) the next time you change the oil, but don't drop the oil now just to do it as you'd just be wasting your money with putting such a good oil in this time.
Re: Petter PAZ1 Oil
When i did an oil change on mine, i put SAE 30 in it, the way i looked at it was, what multi grades and types of oil were available when they were designed or built, only my opinion
This is the question i asked on some other forum (twice) and never got a reply
iansw- A credit to the forum
Re: Petter PAZ1 Oil
Multigrades were a replacement for SAE 30 as a mulitgrade offers more protection. Its so your engine is protected from cold starting up to hot motorway running, where as the old oils couldn't offer this. The old diesel engine oil had a detergent in it to help keep them clean from all the carbon build up, but now diesel fuel is a lot cleaner they don't have that worry so much about it, so you can now get a 20/50 oil for your diesel so it will also cover hot and cold running and turbo charged engines. Hope thats helped clear it up a little for you.
Re: Petter PAZ1 Oil
I dunno why you just dont stick to this site adam, just looked at your same thread on other site you had one reply, here theres been 8 messeges, if we dont know the answer we will find it
Re: Petter PAZ1 Oil
And if we don't know we'll give you loads of bulls**t so it sounds good
Re: Petter PAZ1 Oil
Here Here we get better buy the day
Chris Sipping my Kopparberg Pear Cider
Re: Petter PAZ1 Oil
hi CHRIS
dont drink it all
ile have a glass when i get back from stockbridge
if there is any left
mike.
dont drink it all
mike.
Re: Petter PAZ1 Oil
You now what the freedge is like all ways full
Re: Petter PAZ1 Oil
I didn't notice this before so as I said to Ryan:It is better not to use a modern multigrade in an older design of engine. The additives in modern oils do not suit the older bearing alloys. For an engine which is not doing any work it probably does not matter but if you are thinking of working it then use a straight grade high detergent oil. Shell Rotella 30 was probably one of the best. I use Exol classic HD30 for the Gardners etc which I look after. I can let you have some as I buy it by the 205l drum.
Rod
Rod
Roadster- Born to be wild
Oil for PAZ1
Hi
I have a number of lister, petter, and Bernard air cooled diesels, i used to run them on 15w 40 multigrade diesel oil. However i have since changed to a straight SAE 30 oil. Apparently multigrade oils with detergents in them are unsuitable for older diesels that lack a proper oil filter. The trouble is that the detergents in the modern multigrade oils keep the dirt in suspension, normally in an engine with a filter this would not be a problem as the filter would then trap the dirt etc, but with an engine with out a proper filter (most listers and petters of the older type just have a strainer in the sump) the contaminated oil carries on being passed around the various galleries and oil ways, not what you really want! The non detergent oils keep every thing down in the sump in a sludge, preventing it from entering the galleries and protecting bearings etc. Hope this helps, i'm no expert on oil and would welcome any further comments. Cheers, John
Dieseljohnyboy- Born to be wild
Re: Petter PAZ1 Oil
You're generally Ok with the cheaper multigrade oils as they contain very little, if any, detergent.
TBH this is a bit of an old thread. We tend to keep off the subject of oil these days as it tends to spark too much debate. We all know what to look out for now, some of us still use straight oils (although some of them still contain detergents). Others (like me) just use stuff like Comma Motorway, it's about the cheapest multigrade on the market & contains little in the way of detergents.
But really, with most rally engines, it matters little, as they never see much in the way of real work or long running hours. We just want something reasonably thick to stop them smoking & rattling too much!
If you shop around you can get classic oils pretty cheap now anyway, so really it's up to the individual.
Re: Petter PAZ1 Oil
I have to agree with what's been said by both John and Nuts and at the end of the day we tend to let individuals just choose there own oil. As most of these engine don't run that much compaired to a working engine and most of us give an oil change every season we don't find many problems with what ever engine oil we use.
Re: Petter PAZ1 Oil
I have to empty the piggy bank for the Kohler, it takes over 6.5 litres to fill the sump on that one!
Re: Petter PAZ1 Oil
nutgone wrote:I have to empty the piggy bank for the Kohler, it takes over 6.5 litres to fill the sump on that one!
You know shes worth it.
» Petter paz1 oil rings
» Petter PAZ1 Injector Nozzle
» Petter PAZ1
» Petter Paz1 cracked flywheel
» Petter PAZ1 question...
» Petter PAZ1
