My first Stationary engine
Page 5 of 5 Previous  1, 2, 3, 4, 5
Re: My first Stationary engine
Post by Lewis MacRae on Fri Nov 01 2013, 21:36
matt86 wrote:Lewis im going to make you go green with my axle bits for the fairbanks Rolling Eyes
Il take a picture in a minuite in the shed ...
Instead of angle wouldn't it be better with some flat bar ??? If you lived closer i would say come around and i would give you some flat bar .
I suppose but wouldn't it be easier to weld with the angle as the flat bar wouldn't move as much? I'll have a look when you put the pics up
Post by matt86 on Fri Nov 01 2013, 21:38
i see your point if its a bigger engine but i have done it with up to 3hp engines and put 2 coach bolts through each side through the timber and never had a problem .
Post by Abes on Fri Nov 01 2013, 21:40
Even easier way Lewis is to slot the axel rod down a bit of box section and weld that to the flat bar instead
Post by Lewis MacRae on Sun Nov 03 2013, 20:34
I've have done a little bit more today but not a lot as I've been working on the fire this weekend. I've just got some of the last bits ready to prime, main bearing casting and the governor housing. No point putting pics up as not much to see
