My first Stationary engine
+10
Biggusdannus
Jake Birrell
biomed32uk
Carpmanjay
14 posters
Page 2 of 5
Page 2 of 5 • 1, 2, 3, 4, 5
Re: My first Stationary engine
I've never tried them Kev, for the reason you say they look plastic! and wouldn't be of much use on an engine, look good for stripping paint off wood LOL. So if your saying they work I might give one a try as I'm fed up with buying wire wheel brushes.
stationary stu wrote:I've never tried them Kev, for the reason you say they look plastic! and wouldn't be of much use on an engine, look good for stripping paint off wood LOL. So if your saying they work I might give one a try as I'm fed up with buying wire wheel brushes.
I was just thinking the same thing myself.
I would add though, the wire brush wheel I use on my drill is one of the knotted/twisted ones, with the red centre disc like the angle grinder ones Stu linked to earlier. These are much better than the other ones, they are much stronger & last a lot longer. I've only got one & I've had it since I started with my Tarpen last year! It's coming towards the end of it's useful life now but has lasted me ages!
I will try one of Kevs sanding pad thingies though, I've seen them before & wondered if they were any good. But if Irwin are doing them they can't be bad, their stuff tends to be very good, their stanley knife blades are fantastic, expensive but they easily last 3 times longer than a normal one.
Sorry about the lack of progress but I have been working on a winch mount for the trailer but today got some more paint stripped!
Lewis it might be best if you just do a bit at a time then take a break so you don't get fed up, when my son was a teenager he would never just do one thing at a time, he was everywhere so as not to sicken himself of the same boring job. He's in his 20's now and still the same no patients.
I know, Its been a while but I got some work done today . I got the fly wheel in primer, The silencer in first coat and the chain guard, oil filler cap, Bearing cap and top plate in first coat! I also got the mag cleaned up. BUT as Matt (nutgone) knows it didn't go well, I got dust in the paint
Parts in first coat! by LewizMacRae, on Flickr
Dust on the chain gaurd by LewizMacRae, on Flickr
exhaust for a lister D by LewizMacRae, on Flickr
Spec plate by LewizMacRae, on Flickr
coming on a treat - nice exhaust
steve w- Life Member
whole exhaust system is brand new. Just need to get a flange!
Lewis you'll just have to try and rub it down (lightly) to see if you can flatten the dust on the paint work. Try to find out where the dust/draught is coming from, gap under door and put something down to stop it, also wet the floor so the dust all sticks together and won't blow into the air.
Good job shame about the dust,
Also, don't forget (along with a whole bunch of other tips) these engines are only ever viewed from about 6 feet away, take a couple of steps back & look again .
Also, if that's the first top coat then that's fine, as long as the final top coat goes on OK, then you're laughing.
Painting is a job of patience, you really need to pick the right day, not just for the weather, but also for your mood. If you're not feeling relaxed & patient, with plenty of time on your hands, then do it another day.
thanks guys I will definitely use that advice is painting outside an option, Like on a sunny day?
Can be done, I used to do it. But it's not known for it's good results.
However, I do know someone who once spray painted a whole coach outside. I never saw the results myself.
If painting outside you need to remember a couple of things.
Firstly, if any little flies or blowing seeds etc land in the paint just LEAVE THEM! They will brush off fine once the paint has dried. Trying to remove them from wet/drying paint will just mess up the finish.
Also, don't leave it too late in the day. Once the sun starts to go down and the air cools it will bloom the whole finish. Make sure it will be at least touch dry before the temperature starts to drop.
I painted my parent's Dutch barge a few years ago and found all this out to my cost. In the end it looked pretty damn good. Just choose a nice warm day, not too humid and try to keep out of any dusty environments like rally fields
nutgone wrote:Can be done, I used to do it. But it's not known for it's good results.
I've painted buses outside but you have to pick your day very carefully, a hot day with no wind is perfect as the paint drys quick so less chance of flies etc getting on it. As Nuts says leave till dry as you can't see flys legs stuck in the paint once you've wiped the fly away
stationary stu wrote:nutgone wrote:Can be done, I used to do it. But it's not known for it's good results.
It would be a couple of weeks before anything gets done as I have homework then I'm away at a roupe on Saturday and at a show sunday
Last edited by Lewis MacRae on Wed Jun 05 2013, 08:06; edited 1 time in total (Reason for editing : change spelling)
Lewis MacRae wrote:stationary stu wrote:nutgone wrote:Can be done, I used to do it. But it's not known for it's good results.
It would be a couple of weeks before anything gets done ass I have homework then I'm away at a roupe on Saturday and at a show sunday
you may want to watch your spelling on your homework
blackvanman- Life Member
:stick lol: :stick lol: :stick lol: :stick lol: Your bad Andy.
Got some more bits in first top coat today. also pic of flywheel in primer.
Other parts in first top coat by LewizMacRae, on Flickr
flywheel of a Lister D in primer by LewizMacRae, on Flickr
Looking good Lewis.
cheers
Looking good Lewis, have you sorted out your dust problem?
No not yet, it's only the first coat so at the moment it's no big issue
Lewis MacRae wrote:No not yet, it's only the first coat so at the moment it's no big issue
Lewis all coats are important, if you get a run or a bit of dust on it now by the time you get the last coat on, it will stand out a lot more.
All coats are important, but the closer you get to top coat the more important the coat is.
It's a bit of a paradox, a good finish is dependant on what is underneath it, but if anything is going to go wrong, you want it to go wrong on any but the final top coat, because then you will have a chance to correct it & still get a good, single top coat (painting a top coat in several different applications is generally not going to look good, it really needs to go on in one continuous coat, which is why it's so important to have all mistakes removed).
So yes & no.
Also, don't forget, all these rules are for the best possible finish. You can still make mistakes & cut corners & be left with a perfectly acceptable finish, it all depends how picky you want to be.
So yes & no.
I've sanded out the runs would that help smooth out the second top coat ?
Lewis MacRae wrote:I've sanded out the runs would that help smooth out the second top coat ?
Yep, that's the way. Nice & smooth for the final coat.
» Jap stationary engine F10
» My new Stationary engine
» jap 80 stationary engine.
» Help with a Stationary Engine
Page 2 of 5
