Help lister d spark plug ?
Post by Lankypaul on Fri Apr 19 2013, 12:19
I have a lister d that I have rebuilt and had running but took a few things off the clean it up and my little one has lost the spark plug and havnt a clue what plug to put back in can any body point me I the right direction
Lankypaul
Re: Help lister d spark plug ?
Post by blackvanman on Fri Apr 19 2013, 15:41
Lankypaul wrote:I have a lister d that I have rebuilt and had running but took a few things off the clean it up and my little one has lost the spark plug and havnt a clue what plug to put back in can any body point me I the right direction
NGK AB6 Smile
Post by Lankypaul on Fri Apr 19 2013, 17:05
Many thanks will pick one up tomorrow
Lankypaul
Post by jay on Fri Apr 19 2013, 17:11
local car parts sell them cheap halfrauds are expensive as well..
8 com is better but u wont find a new 8com anywhere..
When u get new plug buy a few as sods law u buy 1 u will need one just when the shop has sold out
jay
Post by blackvanman on Fri Apr 19 2013, 17:28
jay wrote:local car parts sell them cheap halfrauds are expensive as well..
Halfords don't sell AB6's (or any 18mm plugs Sad ).
Halfords are quite cheep on plugs though, "IF" you have a trade card, a £4 plug comes out just over a quid on trade, just goes to show Very Happy
Post by nutgone on Fri Apr 19 2013, 19:14
Always have a few spare plugs. They're one of those things you start to collect as you go on with the hobby. Soon enough it won't matter if one goes missing, you'll always have another knocking about.
Worth picking up the older "Detachable" ones at shows (the ones you can take apart to clean). They last for ever. But always best to test that there is a connection between the terminal & the centre electrode with a multimeter. Some plugs corrode inside & lose this connection, they will still spark as the spark jumps the gap inside the plug, but they will put a lot of strain on your mag & will give you running troubles. Champion 8COM plugs are one of the worst for this, but DON'T throw them away! They can be repaired. I will be writing a thread on repairing these plugs very soon.
Specialists say you should even check brand new plugs for this (it's easy enough with a multimeter, only takes a few seconds), as some have manufacturing faults or are wrongly marked up "resistor" plugs. You should never use a resistor plug on a magneto (or a "suppressor" or "resistor" plug cap).
Blimey, I should really do a quick thread on plug care. Shocked
Post by stationary stu on Mon Apr 22 2013, 11:05
This is a handy site for getting most of your plugs etc just some of there prices can be a bit high so you'll need to check the price on ebay before ordering anything. It has a good section that allows you to cross referance plugs for others that will fit.
http://www.gsparkplug.com/shop/
Post by StewartH on Sun Oct 20 2013, 19:19
I know this is a bit slow on the response but have just found The Green Spark Plug Company selling new 8 Com plugs ...... Nowt to do with me and at 15 pounds each you can make your own minds up.. Just thought I'd let you know. You can find them on eBay as well as
Gsparkplug.com
If I read the thread above correctly they are a better fit than the NGK AB6
Best
Hamish
StewartH
Post by matt86 on Sun Oct 20 2013, 19:33
StewartH wrote:I know this is a bit slow on the response but have just found The Green Spark Plug Company selling new 8 Com plugs ...... Nowt to do with me and at 15 pounds each you can make your own minds up.. Just thought I'd let you know. You can find them on eBay as well as
Gsparkplug.com
Best
Hamish
Hamish you can use champion d16 as well .
Post by Villiers on Sun Oct 20 2013, 19:45
6 new here...
http://www.ebay.co.uk/itm/Champion-8-com-spark-plugs-boxed-and-unused-x6-/221299153584?pt=UK_BOI_FarmingEquipment_RL&hash=item3386751ab0
Post by Lewis MacRae on Sun Oct 20 2013, 19:48
bit expensive
Post by Villiers on Sun Oct 20 2013, 19:53
£7.50 inc postage, not as bad as "Green spark plug" at £15 ex VAT!
These are PROPER 8COM plugs, not an NGK rip off of a 18mm plug.
Post by nutgone on Sun Oct 20 2013, 20:03
Proper detachable ones too Smile . They were on my watchlist, just to see what they went for compared to G.Sparkplugs.
Does Greens actually have any in stock then? They list all sorts but most of what they list they never have in stock.
Post by Matth92 on Sun Oct 20 2013, 20:21
You can buy 18mm to 14mm adaptors, seeing that some of my engines are 14mm and some are 18mm, ive started buying them and putting them in the 18mm ones, so I can run them all on 14mm ones
Post by matt86 on Sun Oct 20 2013, 20:24
Matth92 wrote:You can buy 18mm to 14mm adaptors, seeing that some of my engines are 14mm and some are 18mm, ive started buying them and putting them in the 18mm ones, so I can run them all on 14mm ones
a man of your means could knock some up easy enough surley ???
Post by Matth92 on Sun Oct 20 2013, 21:03
Its all about time!!
Post by matt86 on Sun Oct 20 2013, 21:04
and if i remember are they around £8 each ....
Post by nutgone on Sun Oct 20 2013, 21:07
Some engines don't like them much as they can effect the reach of the plug & overall combustion chamber shape, but most engines will be fine on them.
I usually get mine from engines I buy. So far I've got 2 or 3 of them from various engines.
You can't beat the old detachable plugs though, especially on old 2-strokes & the more worn out, older, 4-strokes, where the plugs need cleaning regularly. Engines running all day on no load tend to foul plugs up as well.
Post by Matth92 on Sun Oct 20 2013, 21:09
nah, mine were about £3 each:D
Post by Villiers on Sun Oct 20 2013, 22:20
I remember getting a box of 10 brand new 8COM plugs from my local garage for a tenner! He found them in the stores while "Having a tidy up".
Post by blackvanman on Sun Oct 20 2013, 22:52
I was well chuffed to get a NOS Lodge BL14 detatcha for £5.50 shipped the other day, paid about £16 for the last one I found Embarassed , but they realy are like rocking horse poo Very Happy
Post by matt86 on Mon Oct 21 2013, 06:07
now where did you get yours from ?
Post by A Lister on Mon Oct 21 2013, 14:37
The Lister instruction booklets suggest that a Lodge BBL spark plug is used for the petrol Lister D (and the A and B petrol engines too).  Unfortunately, these are no longer made and new old stock (NOS) Lodge BBLs are getting hard to find; used ones still turn up on Ebay and on stalls at rallies from time to time though.  However, don't forget what Nutgone said about testing them with a meter first if you can before you buy, as there are bound to be a few dud ones out there after all this time.
I run both my Lister A and D on used BBL plugs and they seem to run very nicely on them.  I've also used a Champion 8 COM plug on my Lister D (before I found a BBL for it) and it seemed to run fine on it.  Since then, I've managed to squirrel a couple of NOS plugs away, so I should be OK in years to come.  Here's a comparison photo of a Lodge BBL and a Champion 8 COM, you can see the distinctive pink-coloured 'sintox' ceramic insulator on the Lodge plug.  I hope this is useful
Jules.
A Lister
Post by nutgone on Mon Oct 21 2013, 21:32
Them's some damn fine plugs you got there Jules. Green with envy here. alien (sorry about the smilie, was the best I could do).
I will be keeping my eyes open for some NOS 7-COMs for my Kohler (they're actually listed as Champion Number 7, but similar thing). I've currently got 2 7-COMs & 2 8-COMs in it & the 7's fair much better, although it's a clean running engine anyway.
Mostly I just use whatever plugs are knocking about for my engines. I tend to whip them out for cleaning quite regularly anyway on the 2-strokes, as was the norm back in the day. The only 4-strokes I rallied this year was the Kohler (never needed to clean the plugs once all season) & the Briggs, which has knackered rings, so the plug was out on that one as regularly as a 2-stroke anyway.
I do need to get some more plugs though, what with me selling a few engines this year I am running short on them. I don't tend to sell an engine with a valuable plug in, I save the modern ones for those, but I've now run out of modern ones as well!
Don't pay Greens prices though Shocked , would rather use modern I reckon.
Of course if I put 4 modern plugs in the Kohler, that would replenish my stock of usable detachable ones. (a thought that has only just occurred to me Rolling Eyes ).
Post by blackvanman on Mon Oct 21 2013, 23:45
A Lister wrote: Here's a comparison photo of a Lodge BBL and a Champion 8 COM, you can see the distinctive pink-coloured 'sintox' ceramic insulator on the Lodge plug.  I hope this is useful
Did you know Lodge still exist under a different name? And their main product line brand is still sintox? And they found far more profitable uses for sintox than plug insulation? Very Happy
http://www.morgantechnicalceramics.com/resources/mtc-data-sheets-index/scroll down that page a bit Wink
