Marshall Semi-diesel
Today's job was fitting new reed valves to the carriers and refitting to engine. Pic one shows the engine with the valve removed, pic 2 shows the valve installed and pic 3 shows the inlet cover fitted.
Tere are 8 valves on the engine.
more info on the engine can be seen here: marshall
Tony Simons
York
www.tonysimons.me.uk
1913 Hornsby L Type 8HP, 1926 Blackstone 5HP, 1927 Lister D 'Shafty', 1940 Stuart Turner P5LY generating set, 1944 Ruston Hornsby 6PB, 1945 Wolseley WD2, 1946 Norman SC, 1971 Rover 2000 auto, 1990 VW T4 camper, 2002 Land Rover Discovery TD5 Auto, 2005 Volvo S60 auto.
Re: Marshall Semi-diesel
Wow Tony that some size engine. I like the pic where (I think it's you) your standing over the top of the piston, that shows the size of it. It will be a great achievement to get that up and running again, shame you so far away (I'm unable to drive far) as I'd like to have been able to come and see it.
Keep up the great work and keep us informed of how your getting on please.
Hi Stu
I try to get across once a month to work on it. I bring bits home to do. When I get it done they have 3 start-o-matics and a 4 cylinder Petter for me to do!
They are interested in holding a rally there. I already do a car event for them.
If there is enough interest I'll organise it.
Tony Simons
York
Sounds as if you've got a full work load for the next year or two, good luck with them as they will be a great collection to see once there all up and running.
An engine rally sounds a great idea, the main thing to it being succesful is planning the best date so as it doesn't conflict with any other rallies in 100 mile radius. Also plenty of advertising helps.
Good luck,
Good luck,
I was having problems with the big end on number 4 locking the engine when we tightened it up. I had scraped the bearing in as the cylinder had been removed but when bolted to the con rod it locked. Investigation showed the big end bolts were slightly bent. Anyway we set about turning 2 new ones. The thread was 1 1/8" Whit and I cut the thread on the lathe
Tony Simons
York
Great job, it must be nice to have the skills to make something like that also the equipment to do the job.
Great work,
Great work,
» this time its a diesel.
» Id this lister diesel
» Coventry Victor Diesel
» Petter AA1 diesel
» Turner V Twin Diesel
» Petter AA1 diesel
