AK Update!!!
AK Update!!!
Post by Statman on Mon Oct 12 2009, 18:38
Hi Boys and Girls!!
I went to the AK earlier and was really chuffed it started 3 rotations of the flywheel so that was brilliant!!
But i after 10 mins i was getting bubbling from bottom of the hopper but not often just random!
I wasnt really to bothered.......So anyway i topped the hopper nearly to the top and left it but when i looked again after a min i noticed a bit of mayonaise on tappets/Valves so i looked at the hopper more closely and noticed a old repair about 2 inches below the top of the hopper!!
All i need to remember is not to fill it to the top
But if i find another head then i will just replace it or shall i just try to repair it with JB weld?
Im really fond of this AK
What shall i do chaps?
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
try and find a new hopper adam, or easier idea,
Post by RAB on Mon Oct 12 2009, 18:42
convert to a tank cooled, may be easier, trying to find a new head may be difficult
possible spares
Post by RAB on Mon Oct 12 2009, 18:52
http://cgi.ebay.co.uk/Lister-A-Stationary-Engine-3HP-Large-Flat-Belt-Pulley_W0QQitemZ200393763389QQcmdZViewItemQQptZUK_BOI_FarmingEquipment_RL?hash=item2ea8662a3d&_trksid=p3286.c0.m14
Re: AK Update!!!
Post by Statman on Mon Oct 12 2009, 19:01
Thanks Ryan!!
Though its a bit to far to collect?
Thanks for looking out
Bamford EG1
Lister D
Petter AA1
Re: AK Update!!!
Post by JONESEY on Mon Oct 12 2009, 19:02
Try and repair with JB Weld V as much out with a grinder and spread it in. I repaired a Lister L about 15 years ago part off the water jacket missing repaired it ,sold it to my mate and told him he still rallys it today no problems Smile Smile Smile
Chris Smile
dont forget adam
Post by RAB on Mon Oct 12 2009, 19:02
Statman wrote:Thanks Ryan!!
im going that way in less than 4 weeks,
Re: AK Update!!!
Post by Statman on Mon Oct 12 2009, 19:18
JONESEY wrote:Try and repair with JB Weld V as much out with a grinder and spread it in. I repaired a Lister L about 15 years ago part off the water jacket missing repaired it ,sold it to my mate and told him he still rallys it today no problems Smile Smile Smile
Chris Smile
Hi Chris!!
I will most likely do that!
Im a little worried about the bubbles at the bottom as well. Paul Sterling said it could be a possibility its the valve bungs but its defitnatly coming from the bottom but only when running
I do love this engine!
Hi Ryan!!
I forgot about that but id see how much it goes for?
Thanks both
Bamford EG1
Lister D
Petter AA1
Re: AK Update!!!
Post by JONESEY on Mon Oct 12 2009, 19:27
Adam if I was you I would take the bungs out clean them all up and fit new copper washers.
I think I have some down my other house I will be checking on the builders at the end of the week .
Let me now if you want them
Re: AK Update!!!
Re: AK Update!!!
Post by Statman on Mon Oct 12 2009, 19:48
Thank you Chris!!
I will try and get hold of my mate that has the right tool to take them out lol!!
I will get back to you
Thanks
P.s Did you manage to find a pic of the drip oil feed
Bamford EG1
Lister D
Petter AA1
Re: AK Update!!!
Post by JONESEY on Mon Oct 12 2009, 19:50
Ask Ryan to look in the Scania tool kit there is one in there, its the bar they use on the wheel nuts its the right size Smile
Re: AK Update!!!
Post by Statman on Mon Oct 12 2009, 19:52
Lol will do
Thanks
Bamford EG1
Lister D
Petter AA1
Re: AK Update!!!
Post by mike d on Mon Oct 12 2009, 20:55
HI ADAM
the lorry wheel brace fits like a glove
it does the A/B etc
get the extension and you can tighten them right down
when you go to your next sort out look out for one,there always handy to have
regards mike d
yes i have one of those
Post by RAB on Tue Oct 13 2009, 02:24
i often use it to torque my nuts lol cheers
Re: AK Update!!!
Post by JONESEY on Tue Oct 13 2009, 07:52
Ah that answers your qushtion about why we sound different on video :lol2: :lol2: :lol2: :lol2:
Re: AK Update!!!
Post by Guest on Tue Oct 13 2009, 09:23
JONESEY wrote:Adam if I was you I would take the bungs out clean them all up and fit new copper washers.
Exactly what i said Chris.
its a common fault on most A/B types immediately after restoration, but easily cured.
like i say Adam, with that crack, its important that you stop further propagation, otherwise a good heat cycle will open it up, you must drill the ends of the crack to stop it spreading, then grind and fill.
Paul Cool
Re: AK Update!!!
