Villiers fuel tap refurbishment
Post by bluedog on Mon May 20 2013, 13:19
My Villiers MK10 brass fuel tap leaks when closed. Is there a way I can refurbish it?
bluedog
Re: Villiers fuel tap refurbishment
Post by woody on Mon May 20 2013, 19:18
Not sure of the exact design but ...
The tap probably comes apart by removing a cotter pin, and sliding the "bit that turns" out of the body.
There may be O rings in which case replace them and clean the bore of the body.
But if there aren't any, you need to lap the tap into the body with valve grinding paste.
Once complete, reassemble with some grease.
To old to die young
woody
Post by kevjhnsn on Mon May 20 2013, 21:41
hi there woody
if its a brass ewarts 90 degree "pull on" tap
i have already refurbed some with new cork seals re-riveted on the shaft ,and a few are even polished ready to fit
its not a easy job to do at all one slip and the brass plunger is scrap Crying or Very sad ,the seals are an odd diameter to the ones for sale on the flee bay ect
if you like we could do a part-ex with your old one if you wished ???
Post by stationary stu on Tue May 21 2013, 11:06
As Kev says you can buy the replacement plunger on ebay, all they do is put a new cork washer on it. You can also buy the cork washers, I tried to fit one and it kept splitting no matter how much I soaked it etc. Crying or Very sad Doing something wrong. Laughing Laughing Laughing
