H2 pump pressure relief valve
Post by wdf on Fri May 31 2013, 12:24
Does anyone know how tight the pressure relief valve (see pic) I have should be done? and if when tight it is still expected to allow a slight trickle of water out (ie not a perfect seal?)
I have cleaned the seat inside...and cleaned the brass ball.... and even ground it into the seat with some engine valve grinding compund.... but yet when up to pressure, whilst on the hose its plenty of pressure I still get a trickle from the relief valve.
The pressure on the pipe is plenty, and gives enough pressure to provide a high pressure spray...... so I assume this is normal for the valve to not have a perfect seal? (when running it has a pipe that comes from this back into the supply tank.)
I found even if I pushed the spring down harder it still leaked a bit... so its the brass ball itself not being perfect?
When I removed the brass ball I could see that over the years it appears people had removed it and rotated it to get a "good" face for it to seat on... as there were numerous wear mark rings in various places.... looking like over 70+ years it had been swapped around several times....
wdf
Re: H2 pump pressure relief valve
Post by Villiers on Fri May 31 2013, 18:01
It should be a perfect seal when you have two lances in operation and open a little when one of the lance is shut off going to fully open when both lances are shut off, this is to prevent over pressurization and overdoseing of chemicals when only using one lance.
Post by nutgone on Fri May 31 2013, 22:30
Sounds like your ball's worn out! Embarassed
If you can measure the ball you could probably get a replacement (I know a company in America which does bronze control balls very cheap). In the meantime maybe try using something a little finer than valve paste, like Solvol Autosol metal polish. It might just get you a better seal.
Otherwise, it sounds like fair wear & tear after all that time. Nice outfit though 👍
Ball wear
Post by wdf on Sat Jun 01 2013, 00:55
nutgone wrote:Sounds like your ball's worn out! Embarassed
Thanks for that, I mean its all gone perfect apart from the leakage due to ball wear.... I actually have planted a few fruit trees in order to actually make meaningful use of the sprayer.... a shiny new brass ball is definitely in order........
wdf
