Ruston and Hornsby PT
Page 2 of 2 Previous  1, 2
Re: Ruston and Hornsby PT
Post by lister dan on Fri Jun 28 2013, 18:25
Nice to see that you got the pt running .I would like one soon.
Daniel.
lister dan
Post by Gary.B on Sun Jun 30 2013, 15:47
Hi guys,
I'm getting oil leaking from between the mag and the timing gear housing. I'm obviously missing a gasket or washer, can someone tell what it looks like and where it should fit.
Thank you. Smile
I don't actually have a clue what I'm doing. Rolling Eyes
Gary.B
Post by Foden on Sun Jun 30 2013, 18:05
Gary.B wrote:Hi guys,
Thank you. Smile
 There is neither a gasket or seal Gary, I usually just push the mag fully forward before tightening the bolts.  However a circular gasket or a smear of Hylomar or similar would do no harm.
Post by Gary.B on Sun Jun 30 2013, 18:08
Ok thanks Pete that's great.
Gary.B
Post by nutgone on Sun Jun 30 2013, 19:08
When I restored the Ruston Hornsby 6PB for Mark I made up a circular gasket to go between the mag & the gear case.
Do you have any gasket paper? There's an eBay seller called TYM seals & gaskets who stocks Flexoid paper, I have loads of off-cuts which would do the job if you want. I can stick a selection into an envelope for you. 0.8mm would do the job quite nicely, but you'll have to re-do your timing again to get it in place, unless you slit it & get it in there.
Post by Gary.B on Sun Jun 30 2013, 19:46
Thanks Nutts, I have some gasket paper and some nice cork rubbery stuff that I think would do the job. I don't want to use any sealant at this stage as the mag is on loan from a friend.
Gary.B
Post by nutgone on Sun Jun 30 2013, 20:07
Don't want anything too thick, but you'll know best as you can see the gap. Just whatever will fit in there really. Maybe give it a smear of grease (especially if it's gasket paper), to help it seal. Job's a good'un. Very Happy
Ruston engine
Post by gerry garnham on Fri Oct 18 2013, 20:31
Hi Gary, Did you get your Ruston PT dated. I may be able to help if you give me the engine number. Regards Gerry
gerry garnham
Post by Gary.B on Sat Oct 19 2013, 10:34
Hi Gerry,
This is the info I received:
Ruston PT 216049 was sold in 1941, to Balgownie Engineering & Dairy Supplies Co. Aberdeen, Scotland.
Before the war, PT's were painted Ruston's "Deep Bronze Green". During the war, only War Office Grey was available. When Rustons ran out of green paint, early in 1941, they used up old stock of Hornsby "Bullock Maroon" from their paint store before having to use the War Office Grey.
This is how she's looking just now.
Gary
Gary.B
Post by nutgone on Sat Oct 19 2013, 11:30
Lovely! Very Happy
Post by janner on Sat Oct 19 2013, 12:24
I have "bullock Maroon" here too and nearly used it on the Enfield , but to be onest its more purple than maroon imho , but looking good though, well done
janner
Post by Lewis MacRae on Sat Oct 19 2013, 12:33
Gary.B wrote:Hi Gerry,
Gary
sound great Very Happy Very Happy
Post by nutgone on Sat Oct 19 2013, 12:53
What I want to know is; What part of the "Bullock" was the bloke looking at when he named that paint colour??? scratch
Post by Villiers on Sat Oct 19 2013, 13:25
The inside.
Post by Gary.B on Sat Oct 19 2013, 13:37
Maybe it was a bruised bullock.Basketball
Gary.B
