Lister D governor oiler wick.
Post by Locknut on Wed Jul 03 2013, 17:17
Hi All,
Probably a silly question but my flip top governor oiler has a central pipe/tube which I think is for a wick - if this is so  what should I use for a wick?,how much of the wick should dangle from the thread end into the governor and into the top reservoir of the oiler?,and finally what oil should I put in it?
Any information would be appreciated.Thank you.
Kev.
Locknut
Re: Lister D governor oiler wick.
Post by Biggusdannus on Wed Jul 03 2013, 17:28
The wicks would have been worsted wool, normal engine oil will be fine to use. You can get away without a wick if you squirt a drop of oil down the hole every now and then.
Hope this helps, Dan
Edit - the wick should protrude around 1/8 -1/4" below the oiler
Biggusdannus
Post by Locknut on Wed Jul 03 2013, 17:43
Hi Dan,
Thanks for getting back to me so quickly,it really is appreciated.This is not going to be as much of a problem as I at first thought!All the best.
Kev.
Locknut
Post by kevjhnsn on Thu Jul 04 2013, 01:36
glad to see your already sorted
big or small just ask and were all glad to help if we can on here
Post by janner on Thu Jul 04 2013, 15:02
kevjhnsn wrote:kev
Even a piece of knitting wool will suffice, so long as the oiler is topped up it'll be fine
Janner
janner
Lister D govenor oiler wick
Post by Locknut on Thu Jul 04 2013, 19:03
Hi Kev and Janner,
Thanks for your input - it is much appreciated.
I will try what Dan suggested and not use a wick for a while until I source  some worsted wool - I might also go for a walk round the local fields and see if I can pick up some sheeps wool - I understand that this 'raw' wool is better than knitting wool as it hasn't had all the natural oils removed.
Kev.
Locknut
Post by StewartH on Thu Jul 04 2013, 19:53
I can't believe this is my third post and I am trying to offer advice but I was in the same predicament not so long ago and was pointed towards the round wicks you use in Coleman lamps - depending on your oiler you might need to trim or fold but they work very well (flow is good) and are inexpensive. Not sure if you will find a round wick of the same diameter you need but a flat wick folded or trimmed would do the same job (this worked on a Blackstone in a corn grinding mill! ) Or sheepskin wool from the fence line as Kev states would do the job well. Hamish
StewartH
