Magneto - Ruston PB
Magneto - Ruston PB
Post by Da_Bunn on Wed Jul 03 2013, 19:06
I've spent days trying to remove the magneto sprocket from my RH-PB 1 1/2 hp engine.
The manual says
"Give it two turns ACWs until it goes tight again, then give it a tap with a spanner"
Well I've tried that, I've cleaned everything, spayed it with copious quantities of WD40, tried the gear pullers, tried just keeping turning the nut.
Absolutely nothing.
The sprocket pullers got so tight they slipped and rounded the aluminium where they were placed.
I have a block stopping the engine turning, placed a ratchet on the nut and thwacked it enough timed to wake Mr Hornsby himself, but it just will not shift.
I'm getting concerned that if I use any more desperate measures I will do so serious damage.
Am I missing something?
Help
Da_Bunn
I really need to post more
Re: Magneto - Ruston PB
Post by kevjhnsn on Thu Jul 04 2013, 01:04
is it keyed or taper fit as there not usually threaded on
is there a grubb key hiding away from you
try heating the sprocket with a small heat tourch and see if the oil gets in better
other than that with out a pic  were in the dark other than the men with said engine with  i.e wico a mag or????
us one of the message options in my box to the right side of this message and i can post it on the post for you --------------------------------->
Post by Da_Bunn on Sun Jul 21 2013, 14:02
It just needed a bigger sprocket puller in the end.
Mine was too small and slipping.Mad
Da_Bunn
Post by kevjhnsn on Sun Jul 21 2013, 14:19
Da_Bunn wrote:It just needed a bigger sprocket puller in the end.
well atleast its off now though mate
