Help please, Wolseley WD8 erratic running under no load
+2
Slim
6 posters
I've recently completed my first engine restoration (a WD8) and although it runs well under load I could do with some advice as it doesn't run so well under no load conditions (see video), other WD's under no load in YouTube videos seem to be running quite well - quite even. I assume I need some choke under no load conditions (lever vertical), I've tried that but that speeds the engine up to the point that it starts jumping about a bit too much, I assume I have two issues - one being the governor and the other that I need some choke or am I barking up the wrong tree, am I missing some trick or two ?
NB: There is some movement (adjustment) available in the mag mounting, is the static timing critical with this, mine is set about mid way between the limits of adjustment which means its firing at or very close to TDC, whats the effect of float height on these engines, I assume that also changes the mixture.
Any constructive advice much appreciated as I'm rather new to Stationary Engines, thanks. DC
Slim- Born to be wild
Re: Help please, Wolseley WD8 erratic running under no load
in my opinion in the video it runs like a typical wolselley same as mine but have to have it a notch or two on choke , The guvnor may be worth checking .
matt86 wrote:in my opinion in the video it runs like a typical wolselley same as mine but have to have it a notch or two on choke , The guvnor may be worth checking .
they do have the odd dip when running with no load, all 7 of mine have done it a bit, some of them do seem to run a bit fast, my red one does and adjusting the governor doest seem to make much difference
PROPER JOB
Matth92- Life Member
sounds about the norm to my ears,
all the ones ive had search a little when idoling along
looks great buy the way sweet job
the really quite running ones ,trust me ive asked the owners ,they have spent days and weeks valve gapping to the min and little tweeks here, little file there ect ect
just to get the ruston pb quitness out of them
Matth92 wrote:matt86 wrote:in my opinion in the video it runs like a typical wolselley same as mine but have to have it a notch or two on choke , The guvnor may be worth checking .
If they runs a bit fast its normally because its a 900rpm model, only way to back them down it to drill a new split pin hole closer to the end of the govenor adjustment screw inside the valve cover plate worked a treat o mine
blackvanman- Life Member
Thanks to all for their responses.
Mine does that its fuel staraiton lift the float to it sitts in the grove.
1949 Lister d 1955 Lister D,1937 Lister A,1928 Lister A,1954 Lister B, wolseley wd2,wd8.
Cheers Daniel.
lister dan- Born to be wild
Not being funny Dan but how can it be a engine running fast be fuel starvation? If was starvation engine would be hunting up and down.. Quite a few engine manufacures recommend if a engine wasn't on load to turn the choke on slightly and reduce the fuel if possible.
timing sounds a tad late to me, the impulse should go off just as the crankshaft keyway is at the bottom
PROPER JOB
» Wolseley WD8 running problems.
» What mag to fit a Wolseley WD2?
» putting an engine under load and stuck piston ring
» Wolseley WLB 9
» My Wolseley
» Wolseley WLB 9
» My Wolseley
