Enfield governor spring re-tensioning
Post by janner on Mon Jul 08 2013, 16:19
Hi all, Been looking for a weaker spring for the enfield VS1 today to get the revs a tad lower with no luck , but was wondering if holding the spring in a vices nearly closed and then heating to cherry red will that be enough to soften the spring rate ?? I was thinking it would, but should I want to put it back to normal would it be a case of reversal then douching in oil to re temper ?? Cheers guys
Janner
janner
Re: Enfield governor spring re-tensioning
Post by pjjms on Mon Jul 08 2013, 19:06
If you heat it red hot it will stay in the position it was heated in, nearly closed. I would talk to a spring maker. I had some springs made for a clutch in a vintage car a while back. They ended up costing 3 or 4 dollars each. At that price I did not think it was worth messing around finding springs that as you say are not right.
pjjms
Post by janner on Mon Jul 08 2013, 20:16
Well !!!!!! IT WORKED bounce bounce bounce  Bloody delighted with it , video uploading as we type , you would not believe its the same engine , and I have made it so it can be wound back up for when loading it up , even got it stopping correctly in the shut off lever, runs off the governor now without holding it on the idle adjust lever...be back soon
Janner
janner
Post by janner on Mon Jul 08 2013, 20:44
Here we go chaps and chapesses, very happy now and not hunting at all, well worth the effort, even gave her a de grease and a clean after before putting her away all tucked up , and no piss taking out my shorts and socks Robert !!! affraid affraid lol!
https://www.youtube.com/watch?v=5xGRKiH3GWk
janner
Post by Villiers on Mon Jul 08 2013, 20:46
ME????? Never!!!!!!!!!!!!!!!
Engine runs better anyway.
Post by janner on Mon Jul 08 2013, 21:05
Not running bad for 20 year old diesel and filter eh ??
Was surprised at the lack of Enfield diesel vids on youtube to refer to !
janner
Post by kevjhnsn on Tue Jul 09 2013, 02:09
so it was to do with the cross rod then its part of the guveroirs then
sounds sweet at a nut know mate
bet your well happier with it now
and soon be going to a new trolley then too
Post by janner on Tue Jul 09 2013, 07:48
kevjhnsn wrote:so it was to do with the cross rod then its part of the guveroirs then
Kev, it was the tension that was wrong plus the adjustments were way out too, they were probably right fr a genny set but no good for rallying !! yes well happy with it, don't see many of them on the field down here, will be making a trolley soon, do enjoy woodwork
Janner
Edit ! Don't see any down here.
janner
Post by kevjhnsn on Tue Jul 09 2013, 17:27
Janner
Post by janner on Tue Jul 09 2013, 19:20
Started building the trolley tonight, that'll get it out in the field then it can be done properly this winter coming for next year.
Janner
janner
