Lister D Governor
Lister D Governor
Post by bradders on Mon Jul 08 2013, 18:11
More problems! How does the governor go together? It's a pain at the moment and pretty much the last hurdle until this is done!
Thanks!
bradders
Re: Lister D Governor
Post by Foden on Tue Jul 09 2013, 17:55
bradders wrote:More problems! How does the governor go together? It's a pain at the moment and pretty much the last hurdle until this is done!
Thanks!
 More information please, not giving us much to go on?  At a rough guess it will be the opposite of how it came apart........Laughing
Post by bradders on Tue Jul 09 2013, 19:41
Sorry! I meant the governor linkage, just where it attaches to on the governor and how else it attaches...?
Thanks!
bradders
Post by Foden on Tue Jul 09 2013, 19:56
Well basically the horizontal bar is as in the photo, it has a Thackray washer (like a double spring washer) at the left hand end and it is secured by the brass cup and locknut at the governor end.  There should be a little tension on the bar to stop it flopping up and down when running and the small roller should be central to the governor pushrod coming from the governor housing.  The engine in the pic is my DK so the vertical rod is in a different position but otherwise it is similar.
Post by bradders on Tue Jul 09 2013, 19:59
Thanks! Hopefully that should be the end to all my problems!
bradders
