Boulton & Paul
+3
StewartH
7 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: Boulton & Paul
quite true there , i think i could pi$$ more than they pumpVilliers wrote:Indeed, Although I like the Blake pumps (Got offered the choice of 50 once, all with hoses, lances and electric motors) I don't like the piss poor amount of water they pump, even a little domestic will out pump one of those in GPH.
my joseph even pumps a a fair amount for running slow , wonder what it be like if run alot faster
Re: Boulton & Paul
[quote="matt86"][quote="Villiers"]Indeed, Although I like the Blake pumps (Got offered the choice of 50 once, all with hoses, lances and electric motors) I don't like the piss poor amount of water they pump, even a little domestic will out pump one of those in GPH.[/quote]quite true there , i think i could pi$$ more than they pump
my joseph even pumps a a fair amount for running slow , wonder what it be like if run alot faster [/quote]
It would pump a lot more....
Re: Boulton & Paul
Bit more cleaning and "rework" done tonight, finished off the valve chamber, cleaned out the threads for the pipework with a 1.25" tap, all cleaned out well with minimum damage found after cleaning.
Nice and clean now, was 4 this size.
The drain plugs were bunged up solid with crap and not a pipe thread, as I only had one of the original plugs I decided to tap them out to 1/4BSP and just add some normal plugs for these.
If you look here you can see what I mean about the castings being very poor, this ridge is about 4mm high and almost as wide.
Finished up with tonight parts coated with a coat of red oxide, next will be the under coat.
All I have left to clean up now are these parts and the pulley, might see if I have a flat belt pulley for this as I think it would look better for it.
Re: Boulton & Paul
looks like you have been busy Rob .
keep up the good work ... i didnt know screwfix did red oxide
Re: Boulton & Paul
Ye looking great, soon have her pumping gallons !
Re: Boulton & Paul
[quote="matt86"]looks like you have been busy Rob .
keep up the good work ... i didnt know screwfix did red oxide [/quote]
http://www.screwfix.com/p/no-nonsense-oxide-primer-red-750ml/48712?_requestid=284733
Re: Boulton & Paul
is it any good ?
wonder if you can thin it and spray with it ?
Re: Boulton & Paul
Wouldn't bother thinning it, it's as thin as piss straight from the tin! That's why I like it, it covers well and doesn't "skim" over pits in the casting.
I get on ok with it and I can't paint!
Re: Boulton & Paul
says the one who paints most thingsVilliers wrote:Wouldn't bother thinning it, it's as thin as piss straight from the tin! That's why I like it, it covers well and doesn't "skim" over pits in the casting.
Re: Boulton & Paul
Just goes to show what good paint it is then, doesn't it
Re: Boulton & Paul
all this painting talk is making me thinking about painting the fairbanks
Re: Boulton & Paul
Good idea, will look so much better than covered in rust.
Re: Boulton & Paul
one problem i see with that ..... Its not covered in rust its a older maroon paintVilliers wrote:Good idea, will look so much better than covered in rust.
Re: Boulton & Paul
Bugger that, to hard to polish, new paint is all shiny and bright, not dull and lifeless
Re: Boulton & Paul
thats exactly what this is ... its all flat and dull .Villiers wrote:Bugger that, to hard to polish, new paint is all shiny and bright, not dull and lifeless
i need to find some paint now ... its a dark green on the fairbanks but its not like mid brunswick green . Any suppliers of paint thats not too expensive like craftmaster ?
Re: Boulton & Paul
I'm a "whatever I have" man, most of mine are Dulux painted. Go for Craftmaster, there paint is fairly good.
Re: Boulton & Paul
so is the price tag not sure if need to strip paint all off as its a sound base so could just flatten it back and paint over .Villiers wrote:I'm a "whatever I have" man, most of mine are Dulux painted. Go for Craftmaster, there paint is fairly good.
Re: Boulton & Paul
I always strip right back to more or less bare metal, that way you know you are not going to have problems. More work that way but less chance to go wrong if the paint doesn't take.
Re: Boulton & Paul
surpose in this case the fairbanks has not got alot of parts to strip off or alot of paint to cover ....Villiers wrote:I always strip right back to more or less bare metal, that way you know you are not going to have problems. More work that way but less chance to go wrong if the paint doesn't take.
Re: Boulton & Paul
I have been tempted in the past to 'paint over' but in the end I stripped the old off instead and started from scratch. That way you dont cover a lot of the detail which thick coats of paint tends to do, I dont bother filling pits etc and flatting down though as I'n not trying to win a concours event! I looked at my first D type yesterday which was buried under sheets at the rear of the garage and (apart from where I had to remove the head to replace the gasket a few years ago) the nearly 20 year old paint is still good and would shine up nicely. Just a shame that I cannot get the same paint these days (maker no longer trading) as touching up the damage would improve it no end.
Makes me laugh when I read of folk 'restoring' an engine over a weekend, oh no they haven't!
Re: Boulton & Paul
I'd leave that for a bit Matt, not that bad, my appletop is worse than that and I'd happily rally that for a few more years, give it a squirt of WD40, be supprised how that brings up the paint.
Re: Boulton & Paul
Pete , i might be tempted just to give it a good rub down and flatten off with some wet and dry on the main casting and should be good for a base as the paint it tough as hens teeth !
only thing is the winter in coming up and wonder about paint drying .... guess i will have to have the heather on in the shed .
Re: Boulton & Paul
i taken your comment on board Rob but the pictures do lie in places it needs doing and not keen on the maroon ... plus i need something to do in the winter !
Re: Boulton & Paul
Will that be 'Lucky Heather' in the shed Matt? I bring anything small enough indoors for painting during winter, that little shearing set was done in the loft last winter! I also painted my WD in the kitchen, got an understanding missus though haha. Put a coat of paint on just before bed time and it is dry by morning, that way the dog doesn't rub against it.matt86 wrote:Pete , i might be tempted just to give it a good rub down and flatten off with some wet and dry on the main casting and should be good for a base as the paint it tough as hens teeth !
Re: Boulton & Paul
i meant heater lol !
i can do that with the smaller bits but the block is a different story ... unless i make a start soon and get it stripped and painted before gets too cold ....
» Boulton & Paul no 1 pump
» villiers mk 20 engine
» HELP WHAT COLOUR GREEN FOR VILLIERS
» easy starter
» easy starter
Page 2 of 4
