petter PH1
petter PH1
I have just bought a small dumper with a Petters PH1 diesel can anyone please give me info on the engine or the dumper
james154- Born to be wild
Re: petter PH1
sorry most dumpers have either listers, petters and any other aircooled diesel available
so it could be a thwaites,benford ,ramsomes ,bamford, smalley, winget barford ,muirhill ect ect ect
thwaites and benford and winget are the more common ones
1. is it 2 or 4 wheel drive
2. is it balance lever or hydrolic tip
3. is it rear wheel steer or pivot point steer
4 is there any id plates or lazer cut lettering on the chassis level areas
or on the diff housings and hub caps
if you post pics or send them to me via my options over on the right of this comment ---------------------------------------------------->
ive worked restored and converted many old dumpers over the years , even uprated one to 4 cylinder watercooled and 45mph with air brakes
for my dads contacting comany when i was a dumper driver and doing long distance dispersal of the soils ect
Re: petter PH1
2 wheel drive, balance lever tip, rear wheel steer the only plate on the dumper says casses no db 3063
Re: petter PH1
This is mine....
It is a Benford with a PH1, 8hp at 2000RPM, 3 forward, one reverse, rear wheel steer, trip tip and starts first swing, don't even use the de-compressor.
Very little room in the steering, brakes that don't and a very lively throttle:DÂ
» Petter m 3hp, progress being made at last
» Petter W1H refurb (1950)
» Petter AV1
» Petter A1 vo
» Petter AV1
» Petter A1 vo
