wolseley timing
wolseley timing Empty wolseley timing
Post by Admin Sun Oct 18 2009, 17:28
hi folks, fixed my mag, it was the HT lead faulty, but need to time it, i have a tdc mark on the flywheel i presume that has to be at 12 oclock, but how do i set the mag????????????????? cheers, remember im cornish so an easy set of instructions would be fab lol lol!
wolseley timing Empty Re: wolseley timing
Post by JONESEY Sun Oct 18 2009, 22:27
The mag will only sit in the rubber starting dog one way as long as the valve timings right
Chris Smile
Post by Avandriver Sun Oct 18 2009, 23:43
Turn the flywheel so that the key is at the top
then turn the magneto drive so it stops on the impulse
Put the magneto coupling on the drive gear in the crank case
offer up the magneto to the coupling and turn the magneto drive backward untill it meets up with the teeth and then bolt it up .
To check the timing turn the engine over slowly and the impulse should kick in when the flywheel key is at the bottom
That is now the timing sorted get it running and have a cold beer
Steve
Avandriver
Avandriver
wolseley timing Empty thanks chaps
Post by Admin Sun Oct 18 2009, 23:53
i dont have a rubber starting dog on this one , i have a cog, with lots of teeth lol cheers
