Lister D main Bearing
Post by Lewis MacRae on Thu Aug 01 2013, 10:29
Can I take the main bearing out of a Lister D without taking the piston out. also is there any thing I need to put timing marks on?
Re: Lister D main Bearing
Post by matt86 on Thu Aug 01 2013, 10:49
think so you have to take off the cam side cover under the mag. Where the cam followers are, remove flywheel, and the ring if bolts behind it, and will pull out, leaving piston and conrod in block.
Post by Lewis MacRae on Thu Aug 01 2013, 11:10
the whole engines stripped, only things left are the main bearing and piston/conrod so should be able to just take it out?
lister d block by LewizMacRae, on Flickr
Post by Villiers on Thu Aug 01 2013, 12:05
Undo the 5 nuts around the housing and pull it out.
Post by Lewis MacRae on Thu Aug 01 2013, 13:51
sorry about the amount of questions but wont the piston fall down the bore and what happens to the thing(sorry forgot what called, like a crank web)does it stay there or fall out?
Lister D piston by LewizMacRae, on Flickr
Post by matt86 on Thu Aug 01 2013, 15:48
The crank web will come out with the crank. Tip engine on the side if you fear conrod falling out.
Post by blackvanman on Thu Aug 01 2013, 16:58
this may help: http://www.stationaryengineforum.net/t6528-ed-s-lister-d-little-tlc
didn't take too long to do Smile You only realy need the side cover above the oil filler off for re-allingnment, but as she is already in bits that won't matter Smile
Post by Lewis MacRae on Thu Aug 01 2013, 18:47
done it now:D Very Happy Very Happy
