What Engine oil do you recommend for a lister "a" and "b" types
Post by barrie clement on Tue Aug 06 2013, 17:58
Also where would you buy this oil from
Many thanks for any info
Barrie
barrie clement
Re: What Engine oil do you recommend for a lister "a" and "b" types
Post by Villiers on Tue Aug 06 2013, 18:04
Any cheap oil from any shop that sells it, Asda, B&Q, Morrisons you name it Pal, they sell it. Something like a 15/40 or there abouts, should be SAE 30 really.
Post by janner on Tue Aug 06 2013, 18:20
If you can find a modern version of the SAE30 with a dtergent in it it'll help keep the crank case insides clean, but mine are run on SAE30 , Comma classic seems the best for me
Janner
janner
Post by kevjhnsn on Wed Aug 07 2013, 01:58
oil as janner says
but i always took the side plate off mine and cleaned the side trophs out , of any sludge and dirt that collects there ,as there was in mine slip ring oilers for getting the oil to the timing gears and crank bearings
every little helps as they only hold a pint or 2
